Results 1 to 10 of 10
Thread: icemaker freezing up,wont dump
    Jun 2010
    memphis
    Default icemaker freezing up,wont dump
    Model Number: 106.8562782
    I have a Kenmore model 22 refridgerater and the icemaker is froze up and wont dump the ice,it just makes a noise..Thanks for any suggestions....Robert
    Hi Robert,
    We will need the complete model# of your refrigerator, as they make 2 differnet ice makers for Kenmore.
    Its located inside the refig. section on the upper walls or ceiling
    Jun 2010
    memphis
    Model# 8562782....Thanks Robert
    Thanks Robert,
    Yes, its your ice maker thats bad. You will need a new one.
    Here's the Ice Maker for your model you can order:
    Manufacturer's Number: 4317943
    4317943
    Jun 2010
    Richmond, Virginia, USA
    Actually, this is apparently a very common problem with Kenmore ice makers and I doubt if going to the expense of replacing it is going to solve your problem! Mine is less than a year old and started exhibiting this behavior within a month of its purchase. Finding the reason for it is what brought me to this forum to begin with!
    Mine does this at least once a month, and the only advice Kenmore has is to
    1. Open the freezer door
    2. Turn the ice maker off
    3. Place a large towel under the door
    4. Empty all cubes out that you can by hand
    5. Take a hair dryer to the collection basket
    6. As cubes become loose, remove them (Do not force them or use anything to pry them loose!)
    7. Repeat until you have it cleared down to the chute access at the bottom of the collect basket
    8. Try the basket release button on the side and see if the basket will release
    9. If not, close the door
    10. Hold the ice cube delivery flap open and apply the hair dryer up the chute
    11. Repeat steps 8-10 until the basket pulls up and away from the door. Do not force it!
    12. Once the basket is removed, use paper towels to dry out the chute from the freezer side and the outside
    13. Use the fryer once more to get the chute completely dry
    14. Leave the basket out of the freezer until it is completely dry!
    Be careful! Wear rubber soled shoes while doing this and be careful to keep wet fingers out of the dryer's nozzle end. You're dealing with water and electricity, never a good combination!
    Pagan,
    I've replaced lots of these ice makers for his issue, and it always solves the problem.
    You should'nt have to do all that.
    Jun 2010
    memphis
    Thanks for all the responses. Since I posted about my icemaker, I see what the problem is, but don't know how to fix it. When it takes on water, the fill tube does not hit the cap completely, and some of the water spews out into the ice basket and when the ice dumps, it freezes because there is water in the basket. Any help is appreciated.
    Ok, just reset your fill tube that goes into the back of your ice makers cup, it should have a little play to adjust it further into the cup, also I've seen ice get clogged in that cup, and makes the fill water splash out and into the bucket, check that too.
    Jun 2010
    memphis
    The simple adjustment did the trick,everything is well now....THANKS Robert
    What adjustment did you do Robert?
  1. fill tube freezing on icemaker
    By John0306 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 30th, 2008, 09:51 PM
  2. Icemaker Problem on GE Profile Refrigerator
    By caf@e-navtech.com in forum GE/Hotpoint
    Last Post: June 27th, 2007, 09:13 PM
  3. Kenmore 106.56532400 Icemaker and Voltage
    By crawdad77 in forum Sears Kenmore
    Last Post: May 25th, 2007, 09:24 PM
  4. Kenmore SXS icemaker not freezing cubes
    By okey1 in forum Sears Kenmore
    Last Post: November 14th, 2005, 02:20 PM
  5. Hotpoint icemaker freezing up
    By rgnprof in forum GE/Hotpoint
    Last Post: September 5th, 2005, 02:49 PM
