Results 1 to 7 of 7
Thread: Electrolux GLER331AS1 won't spin
    Jul 2010
    Birmingham, AL USA
    Default Electrolux GLER331AS1 won't spin
    Model Number: GLER331AS1
    Brand: Frigidaire
    Dryer won't spin. Pully and belt are intact. What should I look at next, please? Thank you.
    So when you start it, any sound at all?
    Turn the drum with your hand without clothes, it should turn semi-freely both ways.
    Let us know.
    Jul 2010
    Birmingham, AL USA
    When I press the "start" switch, I can hear the motor. The drum will not spin.
    The drum turns freely by hand in one direction.
    Ok, if the motor is running and the drum is not, it sounds like the belt broke.
    But you need to open your dryer first to see if thats the case.
    This link shows how to open your dryer(UNPLUG YOUR DRYER FIRST):
    White-West, Frigidaire repair info, how does the dryer come apart, front flides and how to replace them
    That drum should turn both ways, so you may have something else going on too. Once you have the drum out, turn the motor pulley or blower wheel both ways.
    Here's the belt for your model you can order here:
    Manufacturer's Number: 134503600
    Let us know.
    Jul 2010
    Birmingham, AL USA
    The belt appears to be intact, fastened securely around the drum.
    Jul 2010
    Birmingham, AL USA
    I will remove the drum and follow your instructions regarding the pulley and blower wheels. Thank you.
    Ok, because if you hear the motor running but the drum not turning then its likely a idler pulley issue if the belt isn't broken. If the motor is just humming and not running, then its likely a bad motor.
    I open the dryer door, have someone hold the door switch in, then I hold the start button and turn the drum with my hand, if it starts turning on its own, its definitely a bad motor.
    Here's the motor for your model, You can order it here:
    Manufacturer's Number: 131560100
    131560100
  1. FIXED: Kenmore Washing Machine Spin Stops at Spin Cycle
    By kdierk in forum Sears Kenmore
    Last Post: October 17th, 2011, 12:43 PM
  2. Frigidaire Front loader no final spin fwt449gfs0
    By lowbus in forum Frigidaire/Electrolux
    Last Post: December 2nd, 2008, 12:13 PM
  3. Knocking during end of spin cycle
    By soggypants in forum General Appliance Chat
    Last Post: June 12th, 2007, 09:13 PM
  4. Neptune 9700 Spin Cycle problem
    By DanO in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 29th, 2006, 12:09 PM
  5. 110-92582110 won't spin
    By jedd in forum Sears Kenmore
    Last Post: September 28th, 2005, 10:51 PM
