Results 1 to 6 of 6
Thread: GE Electrice Range - cannot control oven temperature
    Nov 2005
    Virginia
    Default GE Electrice Range - cannot control oven temperature
    I have a GE Electric Range that had the lower oven heating element fail, (it melted in one spot.). I have replaced the element and now I cannot control the oven temperature (may be the reason the lower element melted). The elements are full on in bake or broil respectively no matter where the thermostat is set. Since a thermostat is pretty expensive, $175-$225, I would like to find out how to make sure the unit is faulty.
    The range is a JB450G and I have attempted to check the thermostat with an ohm meter and I believe that it is shorted. The only problem is that I do not have a service manual and am not sure that I am testing the correct terminals on the unit.
    If anyone can help please let me know.
    Alan
    How old is this range?
    When the oven is on, only the bake element should be working(red hot).
    Some of the older GE's used to use both the broil and bake elements just to preheat the oven when you first turned it on, but after that first preheat, only the lower bake element should only be on.
    That model# is only part of it, there should be some numbers after that like: JB450G*J2
    Nov 2005
    Virginia
    I am not sure how old the oven is. The house is like 30 years old but the kitchen was remodeled before we moved in. So I would guess it is 12-15 years old. The model is JB450G*J2 like you said.
    If I turn it to bake the lower element glows red and I cannot control the temperature with the thermostat. If I turn it to broil the same thing happens for the upper element.
    Alan
    Ok, then that means your thermostat is bad, i looked up that model# and it said the digital clock/thermostat was no longer available.
    Is yours the digital clock/thermostat?
    Nov 2005
    Virginia
    First thanks for the help. No it does not have a digital thermostat. I looked it up last night and it looks like this one: Oven Thermostat WB21X5320 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Not sure if it is the exact replacement but it looks like it.
    Thanks again,
    Alan
    Yea, i looked it up again at RepairClinic.com and that looks right.
  1. Control Pad too sensitive on Kenmore Elite range
    By pegleri in forum Sears Kenmore
    Last Post: May 3rd, 2007, 04:27 PM
  2. Jenn-air wall oven doesn't close & temperature is off
    By laroc in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 2nd, 2007, 11:14 AM
  3. Jenn-Air range not holding temperature
    By Nancy Reynolds in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 5th, 2006, 11:55 AM
  4. GE double wall oven temperature control
    By zlbrooks in forum GE/Hotpoint
    Last Post: December 5th, 2005, 12:26 PM
  5. Amana Oven Slow To Preheat
    By scanor in forum Amana
    Last Post: November 7th, 2005, 08:57 PM
