Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Dryer stops after 15 minutes; no heat; flashing lights
    Aug 2010
    NC
    Question Dryer stops after 15 minutes; no heat; flashing lights
    Model Number: LEQ2152EE0
    Brand: Frigidaire
    My Frigidaire dryer will run for approximately 15 minutes. There is no heat while it is running. When it stops running the lights on the right side of the panel flash constantly and there are no codes displayed. I have cleaned the vent and lint traps. Any ideas on what is wrong? Thank you in advance for any advice.
    Its possibly your control board thats bad.
    Here's also the repair manual for your model you can print out the sections you need to:
    http://www.applianceblog.com/manuals...Dryer_2005.pdf
    Manufacturer part#134523200 is RepairClinic item#1154933
    Aug 2010
    NC
    Would the board cause it not to heat as well?
    Thank you for your help.
    Yes, seen that happen many times.
    But I always first check the voltage and breaker to the dryer.
    Check your home breaker box to the dryer, I've seen 1 of the dual breakers trip and cause this.
    220-240 volt 3 prong power plug test for a dryer
    220-240 volt 4 prong power plug test for a dryer
    Aug 2010
    NC
    Thanks for the help. I will keep you posted.
    Ok, sounds good, yes please keep us posted.
    Aug 2010
    NC
    Installed board. Dryer runs full cycle now but no heat. Breaker is not tripped and there is good air flow. Would you replace the breaker first or look at the heating element?
    Only way to know for sure is to use a volt meter and test your volts, did you do that?
    Hate to see you change an element and it still not work, only to find out it was the voltage thats the problem.
    Aug 2010
    NC
    Just replaced breaker. Still no heat.
    Ok, just because you changed the breaker means nothing without verifying volts, I've seen new breakers still not produce 240 volts, due to either a bad neutral drop or wiring problems to the dryer outlet.
    But you can go ahead and look at your element, you may see a broken element wire. Lets just hope so.
    Use the repair manual I posted in post#2 to take the front off and drum out.
    Turn the breaker off first before opening it up.
    If a broken heating element wire isn't obvious, You would HAVE TO HAVE a volt/ohm meter to diagnose it, OR get a friend or family member that may have one.
    Here's the heating element assembly for your model you can order here:
    Manufacturer part#131553900 is RepairClinic item#407685
  1. Replies: 8
    Last Post: May 30th, 2010, 03:54 PM
  2. Kenmore Dryer 417.94072301 No Heat
    By brimmyhop in forum Sears Kenmore
    Last Post: September 29th, 2008, 12:46 AM
  3. Duet Dryer stops drying after 15 minutes
    By wrobins in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 14th, 2007, 03:10 PM
  4. Replies: 1
    Last Post: December 26th, 2006, 11:40 PM
  5. Replies: 3
    Last Post: December 10th, 2005, 05:07 PM
Tags for this Thread
