Results 1 to 6 of 6
Thread: Goodman GMP050-3 furnace blowing fuses
    Jul 2010
    Decatur, GA
    Default Goodman GMP050-3 furnace blowing fuses
    Model Number: GMP050-3
    Brand: other
    I have a Goodman GMP050-3 furnace that started blowing the 3 amp fuse on the circuit board when the thermostat is turned on. The heater worked fine during the winter. Now the fuse blows whenever a/c or heat is selected (and temp adjusted). Previously only blew when the fan switch was turned ON. I just had a newer a/c installed and it continuously runs even when the thermostat is turned off. The old a/c did the same thing right before I stopped using it earlier this year.
    The thermostat is a Ritetemp and i just pulled it off the wall (thermostat was turned off). The a/c stopped running. Could the thermostat be bad?
    Any ideas where to start troubleshooting?
    Jul 2010
    Decatur, GA
    I replaced the thermostat and now the heater works again. Still nothing on the a/c side. The fuse blows when the fan switch is ON.
    Jul 2010
    Decatur, GA
    Ok. Now i've fixed the fuse issue and can turn on the fan manually without blowing a fuse (wrong wire to ground). Heater works. The wiring on the furnace circuit board was wired different from the wiring diagram (fixed). This is a used unit which was installed 5 years ago and working until recently.
    When i switch the a/c on, the outside unit fan spins, but the blower on the furnace doesn't start. Any ideas?
    I'm asked MorePower7701 if he could assist you ozzy.
    Jul 2010
    Decatur, GA
    Thanks.
    Feb 2009
    Knoxville
    There should be a switch on the thermostat for Gas/Electric? Pull the cover off the stat, there should be eather a switch or a pin that is jumped out for electric or gas.
    Keith
  1. Jennair microwave keeps blowing fuses
    By zwasdl in forum Maytag/Jenn-Air/Magic Chef
    Last Post: December 9th, 2008, 07:47 PM
  2. Quiet IV blowing control fuses
    By l8nighter1 in forum Whirlpool/Roper/Estate
    Last Post: September 11th, 2008, 11:39 PM
  3. kenmore 110.72992100 keeps blowing fuses
    By mike86ttypee in forum Sears Kenmore
    Last Post: June 27th, 2006, 12:34 AM
