Results 1 to 2 of 2
Thread: Maytag PAV2300 not spinning properly
    Nov 2005
    Williston Vermont
    Unhappy Maytag PAV2300 not spinning properly
    I have a Maytag PAV2300 that is less than 4 years old. It is not spinning properly on heavy loads. The local service guys say this is a common problem and there is nothing that can be done. They also say that the problem stems from the fact that there is not an off balance switch. Has anyone found a way around this? I hate to buy a new washer already. This sounds like a design flaw on Maytag's part, has anyone contacted Maytag?
    Penny
    Could be several things causing this besides the off-balanced loads, A bad motor pivot/spring, belt worn, thrust bearing going bad.
    They did have some snubber problems, white plastic white shavings underneath the washer, so if you see that underneath, thats a major repair.
    Here is a link that will explain more about these washers:
    http://www.applianceaid.com/norgewash.html
  1. Maytag PAV2300 Performa Trransmission
    By jdub in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 31st, 2007, 11:29 AM
  2. Maytag Dryer not starting or stopping properly
    By nereids in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 8th, 2007, 05:47 AM
  3. maytag xrss287bb not cooling properly heater satying on
    By goza21 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 16th, 2007, 10:31 AM
  4. Maytag Atlantis MAV6200AWW Not Spinning
    By CALCASPER in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 17th, 2007, 03:34 PM
  5. Spray Arms not Spinning on Maytag MDB9600AWB Dishwasher
    By paulrhodes in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 19th, 2005, 05:52 AM
