Results 1 to 6 of 6
Thread: Kenmore Elite Oven not working
    Aug 2010
    Maryland
    Default Kenmore Elite Oven not working
    Model Number: 790.79014102
    Hello,
    I have a 7 year old Kenmore Elite gas freestanding range. The cooktop burners are working fine; hohwever the oven is not working. I can type the temperature in on the panel, but it doesn't heat up. This happened for a few days and just last night it started to work again. Would you have idea what this would be? The preheat (top of oven burner) has worked the entire time. Please let me know if there is any other information needed,
    Scott
    Hi Scott,
    When you turn the oven on, look inside the bottom for an orange glow.
    The problem is likely your oven igniter glow bar.
    Here's the cheapest oven igniter glow bar I found for your model you can order:
    Manufacturer's Number: 5303935066
    5303935066
    Jeff explains it here:
    You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
    Courtesy of Gas Ranges, ignition problems, glow coils, spark modules, fault codes, converting to propane, Maytag, Frigidaire, GE, Kenmore, Amana
    Aug 2010
    Maryland
    Thanks! I didn't know if it was that or the chip board that i have read about on here. Just out of curiosity, how did you eliminate the chip board from being the problem
    You would use a volt meter and measure 120 volts at the oven igniter with the oven ON.
    If 120 volts is present, your control board is fine.
    Nov 2011
    Wisconsin
    Thumbs up Cheaper Part?
    Just asking for a confirmation that this part will work.
    amazon.com/gp/product/B001DPQN70/ref=sc_pgp__m_A32GBDTWXA9MO1_1?ie=UTF8&m=A32GBDTWXA9MO1
    Can't beat $11.95, even with 2nd day shipping it came out to $18.44
    P.S. Awesome site, you folks save me TONS of time money and headaches!
    Keep up the great work!
    Well, as I tell others, don't ever buy parts from Amazon or Ebay, this week alone two members did and both parts they ordered came defective.
    Now they are fighting with the Amazon sellers who sold them these parts to get their money back after they both re-bought the parts through our site and both worked.
  1. Kenmore 790 Oven Not Working
    By VMH in forum Sears Kenmore
    Last Post: July 18th, 2010, 11:41 AM
  2. Kenmore elect. oven quit working after cleaning
    By jpriewer in forum Sears Kenmore
    Last Post: February 18th, 2010, 01:23 PM
  3. [FIXED] Kenmore Elite Oven Heating Element not working
    By pjesukie in forum Sears Kenmore
    Last Post: August 23rd, 2007, 01:41 AM
  4. Kenmore Elite Double Oven 911.49053201 - Error F0
    By pdq2 in forum Sears Kenmore
    Last Post: January 15th, 2007, 11:22 PM
  5. Replies: 3
    Last Post: January 11th, 2006, 03:20 PM
