Results 1 to 9 of 9
Thread: Kenmore Refrigerator Compressor not Running
    Jan 2009
    Strasburg, co
    Default Kenmore Refrigerator Compressor not Running
    Model Number: 106.52552100
    I have a Kenmore side by side model 106.52552100. I noticed the freezer contents was melting. Long story short. I came to this site and checked the relay to the compressor. it was burnt to a crisp. i have now replaced the relay but the compressor is not kicking on. I took an ohmmeter to the 3 prongs on the compressor and i get 0 resistance across them but i am not sure if that is normal or not. the compressor cooling fan has not turned on either. Any suggestions? everything else is running. The unit is almost 10 years old
    Are you sure you purchased the correct relay kit?
    Here's the compressor start relay kit for your model:
    Manufacturer part number 8201786 is RepairClinic item number 1177466
    8201786
    Recheck to make sure all your wiring is hooked up correctly.
    Jan 2009
    Strasburg, co
    I do have the right part. Looks just like the picture below. I checked the wiring and it is correct. I alos took an ohmeter to the wires to make sure that although covered in soot they would still conduct. Any suggestions?
    Is the compressor warm to the touch now?
    Do you still have the refrigerator plugged in? If not, plug it in now and open the freezer door and listen to see if your evaporator(freezer) fan is running.
    Jan 2009
    Strasburg, co
    the evaporator fan is running. the compressor is cold to the touch
    Jan 2009
    Strasburg, co
    One more thing. i don't think it matters but i did not install the large black cover piece. i wanted to make sure it worked before i did
    Thats fine.
    Then it sounds like your control board got damaged as well from the burnt relay.
    Here's the control board for your model you can order here:
    Manufacturer part number 8201527 is RepairClinic item number 949546
    Jan 2009
    Strasburg, co
    Where is the control board located?
    Its the main temperature control center in the refrigerator section, which you push the buttons to control the temps.
    Its #6 here:
    http://c.searspartsdirect.com/lis_pn...4026-00010.png
    You remove the console #1 with the #7 screws underneath it.
  1. Kenmore Electric Dryer Won't Stop Running
    By WadeB in forum Sears Kenmore
    Last Post: May 27th, 2012, 12:13 PM
  2. Replies: 36
    Last Post: December 12th, 2009, 01:33 AM
  3. Kenmore elite still not running
    By strat37 in forum Sears Kenmore
    Last Post: November 19th, 2007, 06:28 PM
  4. Kenmore S/S running way too cold
    By BLWorth in forum Sears Kenmore
    Last Post: February 4th, 2006, 09:28 PM
  5. Kenmore 253.8674011 - both sections running warm
    By bunder in forum Sears Kenmore
    Last Post: August 8th, 2005, 08:44 AM
