Results 1 to 9 of 9
Thread: GE Profile Fridge side intermitently hot >85
    Sep 2010
    Panama City
    Default GE Profile Fridge side intermitently hot >85
    Model Number: PSS26MSWASS
    Brand: GE
    Fridge was bought in Nov. 2007. Twice in the past, roughly 6 months ago and one year ago, the fridge side was wayyy hot. Like 91 degrees on the readout. I'm talking plastic milk jug bulging because it was so hot in there. Thought that was too hot for even a failed fridge in house with 72 degree ambient temp, but chalked it up to door being left open and lights cooking the inside.
    Now it has happened three times in last week. Twice was 91-92, last time was 84. The reason I have still chalked it up to door not closing is when I find it in this state, do routine checks, etc, it starts to immediately cool down.
    I've got four kids, but the 2nd instance this week, they were threatened with cancelling xmas, blah, blah if they didn't make sure the door was closed. So anyway, I've started to suspect it may be another issue for two reasons:
    1. The second time this week it happened, I am 99.9 percent sure the door was closed completely.
    2. When I found it at 84, the door was closed for sure, and it had already started to cool down, as I could feel cold air, it just hadn't had time to get cold again.
    So now I start reading about failed mainboards and other things that are fairly common with this style of GE side-by-side.
    Any ideas what may be happening, or does it seem like it simply is the door not sealing properly? Can the lights get it that hot, if the fridge is "working properly"? Is there some auto cutout that notes a problem and shuts down the compressor so it doesn't burn up? I'm clueless really, just throwing random ideas out there.
    Thanks in advance.
    Mitch
    Hi Mitch,
    It definitely sounds like your refrigerator light bulbs are now staying ON all the time the door is closed.
    So either the door is not closing the door switch anymore, or your door switch is bad.
    To test this, unscrew the 2 light bulbs from the sockets and see if you still get the same results.
    Here's the light switch for your model in case you need to order it:
    Door Switch WR23X10530 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Sep 2010
    Panama City
    Jake, I would like to think it is so simple. But I meant to and forgot to mention in my first post that I cannot get that switch to fail by hand. I've flicked it, pressed it, held it down partially and fully. Thinking about putting a cheap video camera in there and try that. Also, I pulled all the light bulbs out after this last time and I am going to see how that goes. Thanks for the reply.
    Ok, yes keep us posted.
    Thats the only thing I can think of thats making it that warm in your refrigerator section.
    Oct 2010
    Yorba Linda, CA
    My GE Profile starting doing this about two years ago. I though the same thing, that the door wasn't shut all the way. A couple months later it happened again, then started happening every month. I replaced the main board and it was OK for another six months, then started doing it again. Same pattern too, happens once, happens again a couple months later, starts happening every month, as of this week is now happening every day.
    Something is in the processor logic is freezing up, causing the light to stay on and the fridge won't respond to the temp control buttons. If the light gets hot enough a thermocouple turns it off, but not before everything inside is overheated and spoiled. Unplugging the fridge and plugging it back in resets everything and the fridge starts cooling down again.
    A main board replacement "might" solve your problem for a while, but it will come back. My advice to you is ditch this lemon. My wife is out shopping for a new fridge as I type this. Needless to say we're not buying GE ever again.
    Jan 2015
    United States
    I realize this post is over 4 years old, but I am having the same exact problem with my GE Profile Side-by-Side (same exact model number as the original one posted). Did anyone determine if replacing the door switch solved anything? From the above, it appears that changing out the board didn't do it. My issue with changing the door switch -- there's 2 panels with bulbs in them, one down low with 2 bulbs, and one at the top with a single bulb. It's only the top bulb that is evidently staying on and overheating everything. No problems (yet) with the lower bulbs. Wouldn't both sets of bulbs be operated by the same door switch?
    Yes, the door switch should operate both light bulbs. The main top bulb is where it gives the most heat off into the refrigerator section, thus keeping the refrigerator section warm.
    To see if the main top bulb is staying on with the door closed is if you have a smartphone put it on video and start recording then put your smartphone inside the refrigerator section and close the door. Then open the door and watch your smartphone video to see if the light bulb went off when you closed the refrigerator section door.
    Jan 2012
    IL
    Thanks for all this info. A jar of salsa fell out of the fridge and broke off the switch day before yesterday. I taped on the part as a temp fix and thought it was working...next morning a waterfall of butter was running down the front of the fridge and the temp said 74. The light was HOT. The freezer temp was a little high but not too bad. I checked here and found more info. My son thought my taping job wasn't working and taped it again. Temperature back to normal today. I'm off to the parts store now for this switch. You guys helped save the day again. Thanks so much!
    Excellent mam, good find, yes the new door switch will fix it.
  1. Replies: 5
    Last Post: December 9th, 2013, 11:50 PM
  2. Replies: 3
    Last Post: August 14th, 2013, 03:01 AM
  3. FIXED: GE profile side by side refrigerator - fridge side not cooling
    By salockridge in forum GE/Hotpoint
    Last Post: May 17th, 2013, 05:19 PM
  4. Replies: 1
    Last Post: May 15th, 2011, 07:49 PM
  5. Replies: 5
    Last Post: September 16th, 2009, 09:41 AM
