Results 1 to 4 of 4
Thread: Freezer warning light/buzzer
    Oct 2010
    Mt.Pleasant, SC
    Default Freezer warning light/buzzer
    Model Number: FFU20F9FW0
    Brand: Frigidaire
    This freezer seems to keep it's contents frozen, but the warning light/buzzer stays on, the buzzer sound is defeatable, the temp hovers between 0 and 10 degrees, My feeling is that since it is a frost free model, that the defrost timer has quit and it is staying in the defrost cycle, as the sides stay warm all the time, in the last few weeks, I had opened it to put some groceries in it, afterwards, the buzzer /light activated, but the temp stayed close to or at where it should, and the groceries are frozen, but the warning light stays on, it used to stay about 0, now it is usually up around 10, but pork loins, frozen meals, etc look to be fine...My guess is that it is staying in defrost cycle all the time, as it is a frost free model..perhaps the defrost timer ?
    If it was staying in the defrost cycle all the time then it wouldn't be cold at all in the freezer.
    Its likely your alarm sensor has gone bad if everything is staying under 10 degrees.
    Here's the alarm sensor for your model:
    Manufacturer part number 5308037992 is RepairClinic item number 642672
    Oct 2010
    Mt.Pleasant, SC
    Thanks, wasn't sure....where is tat darn thing located ? under a square cover inside the freezer ?
    Yes, exactly under a square cover inside the freezer.
    Its #77 under the #78 square box: Cabinet / Control / Shelves parts for Frigidaire FFU20F9FW0 - AppliancePartsPros.com
  1. FIXED: Freezer cold, but Warm fridge side - not cooling? Air flow 101 - HELPFUL INFO!
    By PatrickM in forum Refrigerators & Freezers
    Last Post: November 29th, 2014, 12:30 PM
  2. Replies: 9
    Last Post: August 30th, 2011, 09:53 PM
  3. FIXED: Freezer inconsistent temp
    By hpnutty in forum Frigidaire/Electrolux
    Last Post: February 3rd, 2010, 10:56 PM
  4. # FRS26R4CW3 Freezer doesn’t stay cold
    By vinalexnc in forum Frigidaire/Electrolux
    Last Post: November 26th, 2007, 02:36 PM
  5. GE Freezer -evap motor fan?
    By redlady4850 in forum GE/Hotpoint
    Last Post: November 11th, 2007, 01:41 AM
