Results 1 to 9 of 9
Thread: Flat top hot surface light stays on?
    Aug 2005
    Default Flat top hot surface light stays on?
    Model Number: 790.45799101
    Just installed a used flat top stove and notice that the hot surface light stays on constantly even if the stove has not been used all day and the surface is cold. is this normal?
    Thanks.
    Apr 2009
    No it is not normal, either your element or your switch needs to be changed, not sure on this model, Jake will link you to your correct part. Is there only 1 hot surface light? If not which light is it?
    Yes, thats the big question, if you just have 1 hot surface light for all the surface burners then you'll have to check each burner to see which 1 is causing it to stay ON.
    Aug 2005
    Yes there is only one light, located center front. how do i check the burners?
    I'm really not sure, it was rare that I ever ran across this where just one light indicated hot surface, normally each burner would have its own light.
    You'll likely need to have a appliance tech. out to check them.
    Aug 2005
    will anything be affected if i just leave it?
    No, it will still run fine that way.
    Apr 2009
    Hey Jake, on the ones ive changed (maybe 4-5) for this exact problem, it has always been the right front burner , because its the 1 customers use the most,,, fyi
    Yes, that sounds logical.
  1. Replies: 5
    Last Post: June 16th, 2010, 01:49 PM
  2. Hot Surface Light
    By Luna_Baby in forum GE/Hotpoint
    Last Post: April 25th, 2010, 04:23 PM
  3. Hot surface light.
    By cgueho in forum Sears Kenmore
    Last Post: September 4th, 2008, 09:34 PM
  4. When oven is on, top front is hot hot hot??
    By TnT in forum Whirlpool/Roper
    Last Post: January 7th, 2007, 03:43 PM
  5. Kenmore range; surface hot light never off
    By bongomom in forum Sears Kenmore
    Last Post: June 30th, 2005, 10:07 PM
