Results 1 to 9 of 9
Thread: Fridge no longer cold
    Oct 2010
    Edmonton
    Default Fridge no longer cold
    Model Number: 596.66032600
    Hello,
    I wanted to ask for some assistance with fixing my Kenmore Fridge/Freezer.
    The fridge is not cold anymore but the freezer works. Upon reading some similar posts I have figured out I may have a defrost issue.
    I went ahead and checked out my condenser coils and found them to be almost wholly encased in a block of ice. After manually thawing them out the fridge seems to be working ok, so now I have to figure out which part of the defrost system I need to fix.
    I was wondering if someone could help me out with tear-down diagrams for my specific model. It is a bottom freezer style.
    You would need to ohm your defrost thermostat(WHILE ITS FROSTY) with an ohm meter to check for continuity. Normal ohm reading will be 0-1 ohm.
    The defrost thermostat snaps on the top of your evaporator coil.
    Here's the defrost thermostat for your model:
    Manufacturer's Number: 67003426
    If that checks good, then its likely the control board.
    Manufacturer's Number: 12868513
    The condenser coil isn't in your freezer, thats the evaporator coil.
    The condenser coil is underneath your refrigerator.
    Oct 2010
    Edmonton
    Whoops! I was reading and typing something different. thanks for the clarification!
    Do I need to check the actual heating element as well?
    How exactly do I get at the control board in the top part of the fridge? I didn't see any screws holding the cover on.
    I will check the thermostat tomorrow with my multimeter.
    thanks!
    Yes, also ohm test the defrost heater, that should read about 30 ohms.
    Here's the repair manual for your model, page #32 shows how to change the control board:
    www.applianceblog.com/manuals/16025629.pdf
    Its #5 here:
    Oct 2010
    Edmonton
    So I un-plugged the wiring harness and put my test leads in the plugs for the orange and brown wires. I made sure that I unplugged the heater plug as the orange wire was split onto that.
    defrost thermostat: .04 ohms
    defrost heater: 33 ohms
    Ok, those 2 parts are fine, its your control board.
    This is the control board for your model you can order, they ship to Canada, part#67006740 changes to part#12868513:
    Whirlpool 12868513 CNTRLELEC
    Oct 2010
    Edmonton
    Would that also explain why my fridge hasn't stopped running in the past 3 weeks, except for the times I have un-plugged it? I tried adjusting the temp down to the lowest setting, but it still kept going.
    I will see what the local cost is for the board here and I'll compare shipping it in.
    Thanks Jake!
    Yes, that would explain it.
  1. FIXED: Freezer cold, but Warm fridge side - not cooling? Air flow 101 - HELPFUL INFO!
    By PatrickM in forum Refrigerators & Freezers
    Last Post: November 29th, 2014, 12:30 PM
  2. Replies: 17
    Last Post: June 3rd, 2009, 11:40 PM
  3. Fridge Not cooling but frezzer is cold (help)
    By D33ZZ in forum Refrigerators & Freezers
    Last Post: July 31st, 2007, 11:10 AM
  4. Replies: 3
    Last Post: April 26th, 2007, 11:27 AM
  5. Jennair fridge side not cold after defrost
    By wobbletop in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 20th, 2006, 01:48 AM
