Results 1 to 9 of 9
Thread: Ice maker slow and freezer coils frozen
    Nov 2010
    Bloomington Indiana
    Default Ice maker slow and freezer coils frozen
    Model Number: KSCS25FKSS02
    Brand: KitchenAid
    Hi everyone, read a few posts and hoping someone can help.
    The fridge works fine. We noticed the ice cream in the freezer was soft recently although other items in the freezer looked fine. I found a huge chunk of ice on the back wall of the freezer (inside) and removed it. It was stuck all over one of the slide drawers. As you can see in the pic, all the way up the right side, the bottom 1/4, and across the top of the coils is frozen -even over what appears to be the defrost sensor?
    The biggest thing we notice is that the ice maker takes forever to make ice, even though it seems the air in there is cold.
    Both fans are running.. freezer and condenser in back. coils are clean.
    Hope you can help!
    Thanks!!!!
    Nov 2010
    Bloomington Indiana
    Default 2nd pic - couple hours later
    I've attached a 2nd pic - this is a couple hours after turning the freezer back on. Hope this helps!
    So the top evaporator coils have no frost on them at all?
    2 things would cause this, a condenser clog or a bad compressor.
    First pull the front lower bottom kickplate grille off, just unsnaps, its easier to do with both doors wide open, then vacuum or brush the condenser coils underneath, or use an air compressor to blow the coils clean.
    Its recommended to clean the condenser coils every 6-12 months, especially if you have pets that shed hair.
    Then put that back panel back on and give it 24 hours to see if that resolves it.
    Nov 2010
    Bloomington Indiana
    Default Response...
    Alas, I've already done that - much more than 24 hours ago. About a week ago. I even took a shop vac blower and blew it underneath to get as much out as I could. They are as clean as a whistle now.
    You are correct - no frost on the top side of the coils. Only the larger coil up the right side and top and 1/4 way up as the pic shows.
    I touched the compressor - its pretty hot. Not sure how hot its supposed to get. Couldn't leave my finger on it. Burn pretty quick.
    Ok, then its your compressor going bad. Is the condenser fan next to the compressor blowing air?
    If so, then its the compressor bad.
    Now your model has a 10 year compressor warranty:
    http://shared.whirlpoolcorp.com/asse...02221544-W.pdf
    Which means KitchenAid will pay for a new compressor, but you have to pay the labor when KitchenAid comes to install it, which can be about $200-$300.
    You can contact KitchenAid here for warranty support:
    KitchenAidŽ: Welcome to KitchenAid.com
    Nov 2010
    Bloomington Indiana
    Default Thanks
    Thanks for the help. The compressor fan is blowing. I cleaned it as well when I cleaned the coils and it spun back up when I turned the unit back on.
    Thank you for the kitchenaid contact info. Very helpful!
    Your welcome, keep us posted.
    Nov 2010
    Bloomington Indiana
    Wink Update
    Just keeping everyone posted....
    I called Jerry's Appliances, the best place around here in Indiana to have this sort of work done. Jerry had a heart attack (two, to be exact) last week and can't help me and isn't sure when he will be back, if at all.
    He suggested I call the place where I purchased the unit - Clark's Appliances out of Indy. They contacted Kitchenaid and told me the compressor was covered but no labor and wanted to charge me $550 for labor and $50 to re-add the freon. I am telling them I think that is highway robbery and will look elsewhere.
    FYI! ;-)
    Its going to be expensive anywhere you check, its a huge job to do, about 3 hours labor.
  1. Ice maker problem on ET1LFKXKS03
    By ultimate175 in forum Whirlpool/Roper/Estate
    Last Post: August 9th, 2007, 12:25 PM
  2. GE - Slow making ICE -- I'm puzzled
    By jamiedolan in forum GE/Hotpoint
    Last Post: April 30th, 2007, 12:29 PM
  3. Ice maker very slow
    By chele in forum Frigidaire/Electrolux
    Last Post: July 2nd, 2006, 11:19 PM
  4. Slow Freezer Fan
    By bogreen in forum Amana
    Last Post: February 27th, 2006, 07:23 PM
  5. Bottom freezer slow to cool, min temp 29
    By JandJW.Vt in forum Amana
    Last Post: August 30th, 2005, 04:25 PM
