Results 1 to 10 of 10
Thread: Jenn-Air Oven Door Won't Fully Close
    Nov 2010
    Boston, MA
    Default Jenn-Air Oven Door Won't Fully Close
    Model Number: JMW9530DAS
    Brand: Jenn-Air
    I have a 5 year old Jenn-Air Oven/Microwave combo wall unit. The oven door won't fully close and my wife is flipping out. About 4 years ago we put in a service call and the technician said he did something with the hinges. Now years later it seems to be worse than ever and I am wondering if there is an updated part I can order and install. It just doesn't seem to pull tight enough.
    Any help would be appreciated!!!!
    Model: JMW9530DAS
    Serial #:18xxxxxxxxx
    Joe
    Hi Joe,
    This is the oven door hinge for your model(order 2 for both sides):
    Manufacturer's Number: 74010283
    74010283
    Here's the hinge receptacle(order 2 for both sides):
    Manufacturer's Number: 74011337
    74011337
    Here's the repair manual for your model, it explains how to change the oven door hinges:
    www.applianceblog.com/manuals/16022821.pdf
    Another member had a similar issue, same hinges and receptacles as yours:
    http://www.applianceblog.com/mainfor...wall-oven.html
    Nov 2010
    Boston, MA
    Thanks for the reply! Just curious. Are these parts different from the original (corrected somehow?) or do they just wear out over time?
    Thanks Again.
    Joe
    I don't know Joe if they have been upgraded or not, usually they just wear out over time.
    Jul 2011
    Washington
    Default 27-inch wall oven?
    Hello -
    Are these the same hinges and receptacles for the 27-inch Jenn-Air wall oven? Same exact problem as the post above.
    Model #: JMW9527DAS
    SS# 28746796LT
    Thanks for your help!
    No,
    Your model uses this one(doesn't come in a pair, so order 2 for both sides):
    Manufacturer's Number: 74010284
    Jul 2011
    Washington
    Thanks, Jake.
    Same hinge receptacles as posted above?
    Yup, exactly the same hinge receptacles as above.
    Nov 2012
    Georgia
    I have a June 2005 Jenn-Air Oven/Microwave combo wall unit. I have the same problem...the oven door won't fully close. Can you tell me what part I would need to fix it?
    Model: JMC8127DDS
    Bo
  1. Jenn Air oven won't stay heated
    By HAF1350 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 13th, 2010, 04:06 PM
  2. Jenn Air JGR8875QDB oven too HOT
    By tide1on in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 10th, 2010, 12:16 AM
  3. Jenn Air Oven Won't Heat
    By daverhea in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 27th, 2008, 08:23 PM
  4. Jenn Air Oven turns off during preheat
    By tshurd in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 12th, 2008, 11:26 AM
  5. Jenn Air Wall Oven With Fault Code 1
    By AFH in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 3rd, 2006, 11:52 AM
