Results 1 to 2 of 2
Thread: Ice dispenser works intermittently
    Nov 2010
    Atlanta
    Question Ice dispenser works intermittently
    Model Number: PSS26MGTDBB
    Brand: GE
    I have an ice dispenser that will dispense ice intermittently. The water always dispenses and the ice maker produces ice normally.
    At times when I push the crushed or cubed button the light will dim when I try to dispense; if I let it cycle sometimes the light gets bright and will distribute while other times I must cycle through several times. It seems to help if I hit the light button or the lock button for a few second first.
    I see that some people are replacing the main board; how do I know it isn’t the ice dispensing board? How can I check so that I can replace the correct part and I’m not just throwing parts at it?
    Thanks for your help….
    Thats a good question, but as far as I know there is no way to test if the dispenser board is bad or the motherboard.
    According to others when it does this its the motherboard thats bad.
    Read this entire thread and you will see for yourself:
    http://www.applianceblog.com/mainfor...topic-too.html
    Here's the motherboard for your model you can order:
    Manufacturer part number WR55X10942 is RepairClinic item number 1531075
    WR55X10942
  1. FIXED: Ice maker works, water dispenser does not
    By Brent C in forum Frigidaire/Electrolux
    Last Post: August 11th, 2010, 07:50 PM
  2. Ice maker works intermittently
    By crash613 in forum Sears Kenmore
    Last Post: July 1st, 2010, 10:48 PM
  3. In-Door Ice dispenser works on Crushed ONLY - not on Cubed
    By Simon Crafts in forum Sears Kenmore
    Last Post: February 27th, 2010, 09:08 PM
  4. Replies: 10
    Last Post: July 16th, 2009, 08:17 PM
  5. Ice dispenser problem with GE side by side
    By Jim Smith in forum GE/Hotpoint
    Last Post: July 8th, 2009, 11:38 PM
