Results 1 to 10 of 15
Thread: "E2 -F1-" Error Code...after installing new control board
    Nov 2010
    Charlotte
    Default "E2 -F1-" Error Code...after installing new control board
    Model Number: GW395LEGQ5
    Hello,
    When I try to use my Whirlpool oven Model GW395LEGQ5, the display gives an error code "E2 -F1-", which started after I ran the self cleaning cycle several months ago. After researching online, I thought the culprit was a bad control board, so I ordered the replacement and installed it, only to frustratingly get the same “E2 -F1-“ error code.
    I think I saw a reference that the temperature sensor be bad. If so, is that something that can be fixed without calling in a repairman? Also, the the original board model number is "12-121" by Siebe, the replacement board model number is "12-141" if it matters any.
    Would really appreciate any feedback/help, this issue has been extremely frustrating to fix with Thanksgiving right around the corner.
    Thank you in advance,
    udmercygrad
    E2 F1 - UL A/D error(s)
    1. Disconnect power longer than 30 seconds.
    2. Re-apply power and observe for longer than 1 minute.
    3. If failure remains, disconnect power, replace control.
    Make sure your control board is the correct one.
    Here's the one for your model:
    Manufacturer part number 9753639 is RepairClinic item number 779731
    9753639
    Where did you buy yours at?
    Nov 2010
    Charlotte
    Thanks, that is the exact controller board I purchased "12-141-1" by Invensys. It was purchased from AppliancePartsPros.com.
    Ok, its possibly a defective new board, return it for an exchange.
    Nov 2010
    Charlotte
    Is there a way to check (i.e. with a multimeter) if the board is defective before asking for an exchange?
    Nope, unfortunately not.
    Nov 2010
    Charlotte
    Thank you for the feedback. AppliancePartsPros.com is sending a replacement board. I will post my results once I receive and install the new board (crossing fingers).
    Ok, sounds good.
    Nov 2010
    Charlotte
    Just got the replacement board. I installed it, turned the power back on, and got the same result after trying to turn on the oven. E2 -F1-. What could this possibly be? Sounds like my original board may be fine; all three (including two new boards) can't be defective. Each new board exactly matches the one listed in the photo.
  1. My $2.87 Kenmore 90 Plus Series "Evenheat" Repair - Board 3402605
    By CorinthWestMissileBase in forum Sears Kenmore
    Last Post: July 7th, 2015, 03:53 PM
  2. GE JVM2070SK - 2nd control board dead
    By dfenwick in forum GE/Hotpoint
    Last Post: June 4th, 2011, 07:23 AM
  3. 2nd control board and still not cooling
    By sallzy in forum GE/Hotpoint
    Last Post: June 14th, 2010, 10:36 AM
  4. Kenmore Dryer 417.94072301 No Heat
    By brimmyhop in forum Sears Kenmore
    Last Post: September 29th, 2008, 12:46 AM
  5. motor, motor control or control board???
    By bosshogg in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 21st, 2007, 12:02 PM
