Results 1 to 9 of 9
Thread: Whirlpool Custom Series Refrigerator Squeaking
    Nov 2010
    Allen
    Post Whirlpool Custom Series Refrigerator Squeaking
    Model Number: ET18JKXMWR2
    Hey guys, I've been having problems with this Whirlpool refrigerator squeaking about every 3-5 minutes and won't stop until you hit the refrigerator repeatedly and it's driving me nuts. This is not the first time it has done this either. When I moved in the house late last winter it was doing the same thing and I continued to hit on it for a day or so and it finally stopped squeaking. It sounds like it is coming from the motor or fan that blows the cold air into the freezer and refrigerator. I don't know if the fan is just getting hung up in there or what but it makes an awful loud and annoying noise. Hope this helps?!
    Sounds like the bearing is going out in it.
    Here’s the evaporator(freezer) fan motor for this model(Comes with installation instructions):
    Manufacturer’s Number: 482731
    Nov 2010
    Allen
    Ok, that is what I thought after looking through the parts list. I swearing every appliance in my kitchen is deciding to screw up this week. I've also been having problems with my Whirlpool oven over the past couple weeks...
    Yes, seems like appliances break more around the Holiday season then any other time.
    Nov 2010
    Allen
    I got the new fan motor in place and it seems to have fixed the squealing. I also put a new freezer door gasket on while I had it turned off. The only problem is I can't seem to get it to shut tight now. I put a tie down around it with a little pressure to hopefully form it to the freezer door? Any suggestions how to make this work properly? Thanks!
    Apr 2009
    there is usually a side without a magnet if that's the case for your model, and that side goes on the hinge side
    Good job on the fan motor.
    Use a hair dryer on the door gasket to soften the gasket to seal properly, becareful to get moving the hair dryer and don't let the hair dryer blow in just one spot or that melt the gasket and put a hole in it.
    Nov 2010
    Allen
    Quote Originally Posted by pucara View Post
    I didn't notice any magnet in the gasket maybe because it's so old.
    I'll have to give the hair dryer a shot tomorrow, I got a bungee putting some pressure on it now and seems to be helping the cause.
    Ok, sounds good, keep us posted.
  1. Whirlpool Gold Series
    By Gnolaum in forum Whirlpool/Roper/Estate
    Last Post: May 12th, 2010, 12:20 AM
  2. Whirlpool Gold Series Dishwasher Continuously Runs
    By ilassig in forum Whirlpool/Roper/Estate
    Last Post: April 25th, 2010, 04:09 PM
  3. [FIXED] Whirlpool Imperial Series problem
    By trobb in forum Whirlpool/Roper/Estate
    Last Post: January 12th, 2010, 08:12 PM
  4. Replies: 9
    Last Post: May 9th, 2008, 05:07 PM
  5. Whirlpool QP 850 Series - no pump or water
    By nscpsteve in forum Whirlpool/Roper/Estate
    Last Post: December 24th, 2006, 09:43 PM
