Results 1 to 10 of 11
Thread: KitchenAid Convection Oven Making Fan Noise
    Sep 2010
    Atlanta
    Default KitchenAid Convection Oven Making Fan Noise
    Model Number: KEBC177HWH0
    Brand: KitchenAid
    This single door unit is making a grinding fan-type sound on both convection and non-convection operation. I presume it is the cooling fan - but need idea on how to get at that one to replace. Or is it some other problem? Any tech sheets available?
    Not good on Thanksgiving Day
    KEBC177 is just a partial model#.
    We need the full model#.
    Help Me Find My Model Number - RepairClinic.com
    Sep 2010
    Atlanta
    Default Full Model Number reply
    It looks like the additional model info is the 4 characters at the end: HWHO. That would make it : KEBC177HWH0
    Ok, yes, Its likely your fan motor, its located in the very back of your oven, you'd need to pull it out from the wall, unplug your range, and take the back access panel off to access it.
    Turn the fan motor and blade with your hand and see if it makes that noise.
    Here's the fan for your model:
    Whirlpool 4451583 Convection Fan Motor - AppliancePartsPros.com
    Sep 2010
    Atlanta
    is that the convection fan or the cooling fan? Sound seems to be coming more from top than back.
    Thanks the only fan I see for this model.
    Nov 2015
    New York
    Jake? I didn't see a reply to you on this but just posted my own issue with a New noisy KitchenAid Countertop convection oven model KCO223CU1 that sounds like a fan or motor issue.
    Has there been any word out on these products since 2004?
    What do you mean? Like recalls?
    Not that I'm aware of.
    Sep 2010
    Atlanta
    Exclamation noisy KA oven
    i replaced the oven in my initial post back in 2011 with a Whirlpool knowing they are same as KA. new one was a mess at first with failing door latching circuits, but is noisy now due to rack vibration if they arent tweaked when you load them. have asked a non-affiliated 25 year experienced service guy about going to LG, but he says they have a very high incidence of service problems on theirs also. dont know where to turn o for a good oven tgat cooks quitely
    Yes, he's correct about the LG ones having a high incidence of service problems on theirs.
    I'd suggest Maytag, that's what I have in my kitchen, and it works like a charm, no noise!
  1. Kitchenaid convection oven question
    By wtdoor in forum KitchenAid
    Last Post: March 14th, 2015, 09:24 PM
  2. Kitchenaid Superba Oven making constant static noise
    By charlie8329 in forum KitchenAid
    Last Post: March 2nd, 2014, 03:33 PM
  3. Convection fan making noise
    By 3XRS in forum Frigidaire/Tappan/Electrolux
    Last Post: January 13th, 2011, 09:41 PM
  4. Convection oven excessive noise
    By estaban in forum Whirlpool/Roper
    Last Post: November 26th, 2010, 11:52 AM
  5. Kitchenaid Thermal-Convection Oven won't open
    By coopers in forum KitchenAid
    Last Post: May 18th, 2007, 12:17 PM
Tags for this Thread
