Results 1 to 4 of 4
Thread: GE Profile Harmony WPGT9350C0PL stopped working
    Nov 2010
    Michigan
    Default GE Profile Harmony WPGT9350C0PL stopped working
    Model Number: WPGT9350C0PL
    Brand: GE
    GE profile Harmony washer WPGT9350C0PL stops working after doing the initial load sensing and tries to add water with in 5 seconds it shuts off giving an error "A problem has been detected with this unit".
    Tried the diagnostic it says that the "The motor is not rotating properly. Check and replace if necessary". Does any one know what might be the problem? After reading numerous blogs and forums, most of them say it might be the Hall Sensor.
    Any apppliance guru's have had the similar problem fixed. Please help me.
    Thanks.
    Aug 2006
    NY
    yes hall sensor is common.It sends motor rpm signal to inverter board. It is not sold separately as far as i know. It is part of the Stator-WH39X10004. Resistance should read about 9k ohms between brown and blue wires and also 9k ohms between the brown and red wires.
    Nov 2010
    Michigan
    Thanks jackofalltrades for your help. I was able to buy the Hall Sensor separately and installed it.
    This is the actual part I installed the same as the one that is part of the stator.
    Hall sensor:
    Rotor Position Sensor 6501KW2001A Order now for same day shipping. 365 day return policy.
    Ran couple of washer loads, it worked without any issues.
    Thanks again.
    Aug 2006
    NY
    You're welcome. Thanks for the info about the sensor being sold separately .Nice job.
  1. GE Profile WPGT9350C0PL infuser removal
    By kingdu27 in forum GE/Hotpoint
    Last Post: January 31st, 2014, 10:19 AM
  2. Profile Harmony came screeching to a halt
    By dano126 in forum GE/Hotpoint
    Last Post: June 10th, 2012, 12:57 AM
  3. GE Harmony Profile Washer Error
    By Steve C in forum GE/Hotpoint
    Last Post: November 22nd, 2011, 12:41 PM
  4. GE Profile Harmony Won't Tumble Sometimes (plus hum)
    By lowercase_s in forum GE/Hotpoint
    Last Post: January 16th, 2007, 11:48 PM
