Results 1 to 8 of 8
Thread: Kenmore elite trio frost in freezer
    Dec 2010
    GA
    Default Kenmore elite trio frost in freezer
    Model Number: 795.77719700
    Kenmore elite trio 795.77719700 Bought in June of 08. Freezer is getting frost buildup. Just noticed this am. I take it the door was shut tight since the door alarm did not go off. Verified that the door alarm works and was on. Bottom freezer door appears to be slightly misaligned when closed tight. Right side sticks out slightly more then left side. Wife thinks its been like this since new. TIA for any help.
    Is the frost just inside the freezer? not on the back panel inside the freezer?
    Is everything in both sides still staying cold like normal?
    Dec 2010
    GA
    Jake, Thanks for your reply.
    All over the entire freezer.
    Yes everything cold like normal.
    Ok, then its most likely an air leak causing the excessive frost all inside the freezer.
    You mentioned that door seal problem, but your absolutely sure its still sealing tight?
    Dec 2010
    GA
    Thanks Jake! I will double check that seal and let you know.
    It appears that there has been a lower level of frost the past few days.
    Ok, yes, recheck it, keep us posted.
    Dec 2010
    GA
    Sorry for the late reply. The door must of been leaking air, issue has not returned after not over packing freezer.
    Ok, thanks for the update.
  1. Kenmore Elite Side by Side - Ice in freezer bottom
    By Desertgator in forum Sears Kenmore
    Last Post: September 22nd, 2010, 02:27 PM
  2. FIXED: Kenmore Elite Trio 795.77562600 - no water in icemaker
    By Springer in forum Sears Kenmore
    Last Post: August 27th, 2010, 01:11 PM
  3. Replies: 8
    Last Post: July 20th, 2009, 05:49 PM
  4. Replies: 10
    Last Post: June 23rd, 2007, 09:41 AM
  5. Replies: 4
    Last Post: April 4th, 2006, 01:52 PM
