Results 1 to 4 of 4
Thread: Whirlpool TEDS740PQO Dryer Issues
    Dec 2005
    Ohio
    Default Whirlpool TEDS740PQO Dryer Issues
    First of all, thanks for the website and the help.
    My washer/dryer units are on the 2nd floor of our house, the vent pipe goes straight up about 8 feet and takes a 45 deg. turn (2/3 more feet) and vents out on the roof top. It's a 4 in. duct with a screen cap on the end. I just build the house, the house and the dryer are about 8 months old. The duct, due to the problem described below, now has lint all along the walls of the duct all the way up (not blocking airflow yet).
    Problems: First, the lint screen catches almost no lint. After a load, we pull the screen out and only the bottom right corner has any lint, all of the rest of the lint goes straight into the duct (not good).
    Second, it took about 2 to 4 runs to dry a load. Clothes are not drying. Remember, the dryer is new.
    Yesterday, I had a company come out and inspect the dryer. here's what they told me. For the lint problem, he wasn't sure. He said to try getting a replacement screen and see if that fixed the problem. I looked at the screen, I don't see anything wrong with that. In regards to the heating issue, he replaced the thermostat (thinking the dryer was short-cycling) and suggested I try the panty-hose deal to see if its a duct or dryer problem.
    I guess I just don't feel satisfied with that analysis and am kinda worried about the lint in my duct building up. I'd appreciate any help you are willing to give and happy to answer any questions.
    Many thanks,
    Patrick
    Oct 2005
    Wichita Falls, Texas USA
    Long dry time and no lint on the lint screen all point to a venting problem in the home.....pull the dryer out from the wall and remove the vent hose from the dryer and try a couple of loads, if it does better you know you will have to install some booster fans in your vent system.
    Dec 2005
    Ohio
    I'll give it a try and update. Thanks
    Dec 2005
    Ohio
    Sure enough. After unhooking the dryer, it dried the clothes and lint screen was full. Now to fix the ducting *groans*.
    Thanks again for the help.
    Patrick
  1. Whirlpool Estate Dryer on 110v
    By Noggin in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 17th, 2006, 06:54 PM
  2. Whirlpool Thin twin dryer issues
    By baseballgirl in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 21st, 2006, 06:47 PM
  3. Whirlpool dryer Model LHI 5801WO tries to start, but won't
    By kjnuke in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 17th, 2006, 01:39 PM
  4. Whirlpool Dryer gets Warm not Hot, Takes long to Dry
    By jnicosia in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 19th, 2005, 11:48 PM
  5. [FIXED] Whirlpool Dryer Quit Running
    By RobertC in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 22nd, 2005, 11:10 PM
