Results 1 to 5 of 5
Thread: ice maker is not keeping up
    Dec 2010
    Oklahoma City
    Default ice maker is not keeping up
    Model Number: 106.50592000
    my ice maker makes a little ice, but will not keep up with usage. i have followed advice i found here (check temperature, clean coils, replace filter, etc), but problem remains. sears installed a water line heater when unit was a couple of years old. i would just replace the ice maker, but i'm afraid that will not solve the problem.
    Aug 2006
    NY
    ok...empty the ice bin then wait until the ice maker pops out a batch of cubes. Count the cubes. You should have 7 to 8 cubes. Less than that and your ice maker is not getting enough water. If you are getting 7 or 8 cubes then either the ice maker is bad or the freezer temperature is not cold enough (less than 5 degrees F preferably zero or less)
    Dec 2010
    Oklahoma City
    thanks for the response, jack. i'm getting a full tray when it dumps and it's cold enough, so i will assume that i need a new ice maker. do you have recommendations of where i should get one?
    Aug 2006
    NY
    Instead of replacing the whole ice maker I would replace these parts since this optic system ice maker is expensive
    Tray Thermostat (part #2942) from RepairClinic.com
    "W10190935" Parts from RepairClinic.com
    Whenever you change the tray thermostat, you always have to order the thermal mastic as well to put on the new thermostat.
    Thermal Mastic (part #632968) from RepairClinic.com
  1. Replies: 10
    Last Post: July 16th, 2009, 09:17 PM
  2. Ice Maker 106.2198597 Overflow
    By agodwin in forum Sears Kenmore
    Last Post: May 5th, 2009, 05:09 PM
  3. Superba Ice Maker and Water Dispener
    By Jake in forum KitchenAid
    Last Post: February 3rd, 2009, 11:52 AM
  4. Complete Ice Maker Assembly - For In-Door Ice Models
    By Jake in forum Refrigerators & Freezers
    Last Post: April 29th, 2008, 01:56 AM
  5. Ice Maker Not Working: KitcheAid Superba
    By Hookem in forum KitchenAid
    Last Post: February 2nd, 2008, 06:05 PM
