Results 1 to 4 of 4
Thread: Gas range (oven) problems
    Dec 2010
    Wisconsin
    Default Gas range (oven) problems
    Model Number: GS475LEKS0
    Hello all, I have a Whirlpool Gold Super Capacity 465 gas range, the oven will not consistently light. The range top lights every time no problem. I can smell gas and see the spark lighter sparking but the oven won't fire all the time. I'm hoping someone can point me in the right direction on troubleshooting this thing, thanks in advance!!
    I should add that I just tried it again and it fired right up, and is staying lit no problem, strange...
    Grant
    Last edited by grantk; December 27th, 2010 at 12:31 PM. Reason: Wanted to add a line about retrying...
    Hi Grant,
    Here's another member with a similar issue and the new bake burner igniter fixed his:
    [FIXED] Whirlpool Super Capacity 465 oven - heats inconsisently
    Read page 2 of that thread.
    Its Possibly a bad bake burner igniter.
    Here the troubleshooting flow chart(read this first, and follow the flow chart towards the bottom of this .pdf):
    www.applianceblog.com/manuals/DSI_manual.pdf
    Here's the bake burner igniter kit for your model:
    Part#8190618
    Dec 2010
    Wisconsin
    Default Bake burner/ignitor
    Thanks for the info on the bake burner, I was able to clean the ignitor tip and it appears to be working for now. The ignitor appeared to have some "stuff" on it and after cleaning it up it fires on the first attempt, I will keep an eye on the burner/ignitor assembly and replace if necessary. I understand that the burner/ignitor is an assembly and you cannot just replace one or the other. Is there supposed to be a certain gap between the tip and the housing of the ignitor? Thanks again for your help! Now on to tackle my ice maker issue!!
    Grant
    Yes Grant, I believe so, but don't know how much of a gap it should be.
    Sounds like you got it working again, good job.
  1. Gas vs. Electric Range? Here is one more view...
    By bobl in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 14th, 2012, 09:22 PM
  2. Kenmore gas range - oven burners won't light
    By squirkie in forum Sears Kenmore
    Last Post: January 19th, 2012, 07:45 PM
  3. FIXED: Gas Range / Oven
    By fixthedish1 in forum Frigidaire/Tappan/Electrolux
    Last Post: January 25th, 2011, 09:51 PM
  4. ES400 Gas Range oven light
    By LBest in forum Sears Kenmore
    Last Post: November 22nd, 2007, 05:48 PM
  5. Frigidaire Range - Ongoing problems with EOC (electric Oven Contoller)
    By filterthespam in forum Frigidaire/Tappan/Electrolux
    Last Post: February 23rd, 2007, 01:32 AM
