Results 1 to 5 of 5
Thread: Whirlpool microwave blowing fuse
    Dec 2010
    Washington
    Default Whirlpool microwave blowing fuse
    Model Number: mh3184xps-4
    Whirlpool microwave keeps blowing fuse. I put in a new fuse and if I open or close the door the fuse will blow again. Could this mean I have a bad door sensor? If so what one, I see three of them.
    Aug 2006
    NY
    I can't see a door switch causing the fuse to blow. Since the fuse blows before you even activate the heating cycle the problem is most likely not in the high voltage sector (capacitor, diode , transformer, magnetron). I've had a wire burn off the light socket and touch against the chassis of the microwave. Every time the door was opened or the light switch turned on the fuse would blow. Do a visual check of all the wiring. Use your nose and try to detect any burning smells coming from the microwave then follow the smell to the source.
    Oct 2004
    Bad door switch ( not sensor ) yes.
    Q - My microwave went dead when I opened the door ( same problem as closed the door ).
    A - This often is a stuck or faulty door switch and it has blown the interior microwavefuse.
    They all should be checked.
    LINK> Microwave parts how to test capacitors, switches, magnetrons high voltage diodes
    LINK> CAUTION WHEN REPLACING LATCH SWITCHES
    LINK> Most microwave door switches can be tested for continuity to see if the switch has failed
    http://www.applianceaid.com/
    Appliance Repair Aid
    Dec 2010
    Washington
    Default No power
    Thank you for the posts. I check all the wiring but could not find anything wrong. I also checked all three fuses and they all check out good with my meter. So I plugged the microwave back in and check power in a couple of different spots. All showed 120 in my meter. Now still nothing even with good fuses.
    It seems now that I'm going backwards. I unplugged it and check all three door switches for continuity. Two of the switches have two wires coming off of them and they check out good. The other switch had three wires.
    Check it and couldn't change continuity with the door closed or open.
    So is this the bad switch? Can I pull the door switch out and open it to see if it's bad inside? Witch one is the power relay? Could I have another problem because there is now no power with all good fuses? Thank you for the help..>>
    Oct 2004
    -Sounds- bad.
    Most yes.
    I popped open this one...
    Relays are normally on the PCBoard.
    Sure.
    But we can't see how you are testing....hopefully not to ground.
  1. Over the Range Whirlpool microwave not working
    By 1der in forum Whirlpool/KitchenAid
    Last Post: June 8th, 2009, 01:30 PM
  2. Replies: 1
    Last Post: April 29th, 2009, 11:28 AM
  3. Jennair microwave keeps blowing fuses
    By zwasdl in forum Maytag/Jenn-Air/Magic Chef
    Last Post: December 9th, 2008, 07:47 PM
  4. Kenmore keeps blowing thermal fuse. HELP!
    By tjs in forum Sears Kenmore
    Last Post: December 20th, 2005, 06:16 AM
  5. Kenmore Microwave Oven Fuse Keeps Blowing
    By Belligerent in forum Sears Kenmore
    Last Post: June 7th, 2005, 11:54 AM
