Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Whirlpool Duet GHW9100LW washer drum is clunking
    Jan 2011
    Houston, TX
    Default Whirlpool Duet GHW9100LW washer drum is clunking
    Model Number: GHW9100LW
    When my washer spins it makes a major clunking noise at it approaches high spin cycle. Also, the tub has what looks to be a white plastic front face/flange on it. This plastic front face is not visible unless you pull back the rubber boot that seals between the tub and the front panel of the washer. This white plastic face looks like it is bolted to the tub and spins with the tub. This plastic face appears to be wearing apart because i am seeing plastic shavings in my laundry and can see where the wear is coming from on the plastic face. UPDATE: THE WHITE PIECE IS ACTUALLY TIED TO THE RUBBER BOOT AND IT DOES NOT SPIN WITH THE TUB. IT APPEARS THE TUB IT OUT OF BALANCE FOR SOME REASON AND IT HITTING THE WHITE PIECE AT HIGH SPEEDS, PEALING PLASTIC STRIPS OFF OF IT.
    My questions are:
    1. Can someone tell me how hard it would be for me to replace this white piece or do I need to get the repair man out to do it?
    2. What do you think is causing the tub to be out of balance?
    I am somewhat handy with tools, but am not sure how much of a pain it would be to replace the face. Any assistance would be appreciated.
    Ok, This is going to be a huge job to do if you decide to do it yourself.
    Its either your rear tub bearing or inner tub spider arms have broken causing this issue.
    Here's the repair manual for your Duet, follow the steps it says to do, you can print them out as well:
    www.applianceblog.com/manuals/DuetWasher.pdf
    You do have a 10 yr. warranty on the inner tub from Whirlpool and Lifetime on the outer tub assembly, but you would still need to pay the labor for Whirlpool to install the parts, labor runs about $300-$400:
    http://shared.whirlpoolcorp.com/asse...08181901-W.pdf
    Here's the inner tub assembly for your model:
    Inner Tub assembly
    W10250573
    Here's the front assembly:
    Manufacturer part number 285982 is RepairClinic item number 1058889
    285982
    Here's the rear outer tub assembly(includes bearing already installed) for your model:
    Rear Drum with Bearing 285984 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Jan 2011
    NJ
    I have the same problem and after disassembling the tub found it to be broken inner tub spider arms. Can the spider arm assembly be purchased separately or does the basket need to be replaced?
    No, the spider arm doesn't come separately, you'd need the basket.
    Jan 2011
    NJ
    Thanks Jake ... I was afraid of that. Does the warranty cover broken spider arms?
    Aug 2006
    NY
    Read your owners manual .Under warranty information is should tell you the warranty on the tub. You can call 1-800- 253-1301. Have your model and serial number ready.
    I'm not positive but I believe there is a lifetime warranty on the stainless steel tub. Since the spider is part of the tub and cannot be purchased separately , it should be covered under the tub warranty. Keep in mind that if the tub is covered the labor would not be.
    Jan 2011
    NJ
    Thanks Jackofalltrades ... I will give Whirlpool a call.
    Yes, Jack is correct.
    Mar 2011
    Ft Worth TX
    Are warranties transferrable ? Or is it only for the original purchaser ?
    Yes most are, but contact the manufacturer to make sure.
  1. Whirlpool duet GHW9100LW Hold-to-Start button not pressing & clicking
    By chikoo in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 23rd, 2014, 10:29 PM
  2. Whirlpool Duet Washer drum took on water over night
    By Pez4 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 13th, 2011, 01:33 PM
  3. Whirlpool Duet Model GHW9100LW More MOLD!
    By Slowrunner40 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 24th, 2008, 11:31 AM
  4. Whirlpool Duet GHW9100LW Water Inlet
    By GaryGershzohn in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 13th, 2007, 05:43 PM
  5. Whirlpool Duet GHW9100LW - No Power Condition
    By 450HP in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 18th, 2006, 11:30 AM
