Results 1 to 5 of 5
Thread: whirlpool quiet partner not filling
    Jan 2011
    central indiana
    Default whirlpool quiet partner not filling
    Model Number: DU1055XTPQ
    Have a quiet partner that is not filling
    1. Have the water supply turned on
    2. Have water to the inlet valve
    3. Have 120v to inlet valve
    4. Have brand new inlet valve
    5. Have no water
    Any thoughts/suggestions/coments would be greatly appreciated
    Its very simple, if you have 120 volts at the water inlet valve and no water is coming out, then you have a defective new water inlet valve, exchange it for another one.
    Jan 2011
    central indiana
    What are the chances of getting two bad ones from the same place? Both new in the box. That is where I am at.
    Very slim,
    I don't what else it could be if thats not the problem.
    You'll likely need a appliance tech. to come out.
    Do you have your meter probes on both the electrical terminals at the same time measuring 120 volts?
    Don't measure from the electrical connector to ground.
  1. Whirlpool Quiet Partner III Not cleaning and filling properly
    By dwhacker in forum Whirlpool/Roper/Estate
    Last Post: January 9th, 2011, 12:43 PM
  2. [FIXED] Whirlpool Quiet Partner III Not Being Quiet
    By Knopfler in forum Whirlpool/Roper/Estate
    Last Post: January 5th, 2011, 12:24 PM
  3. Whirlpool Quiet Partner II backed up with sink water
    By JiminySpigot in forum Whirlpool/Roper/Estate
    Last Post: June 12th, 2010, 11:08 PM
  4. Whirlpool Quiet Partner 1 -- Grinding Noise
    By GregMac in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: September 19th, 2008, 01:50 PM
  5. Whirlpool Quiet Partner II DUL200PKQ1 - adjustable top rack
    By oneder in forum Whirlpool/Roper/Estate
    Last Post: January 16th, 2007, 09:57 AM
