Results 1 to 10 of 14
Thread: [FIXED] Frigidaire FTF530FS1
    Jan 2011
    new york
    Default [FIXED] Frigidaire FTF530FS1
    Model Number: FTF530FS1
    Brand: Frigidaire
    I have a problem with my drum not spinning at all. The pump sounds like it is going on so I don't think its the door switch. I have seen in other posts that I can test that with the plastic piece that hangs down in the front of the machine. If I can confirm that the door latch works what would be the next step?
    Thaks for any help
    Aug 2006
    NY
    Your model is not correct . It should be the number 1 at the end not the letter i.
    Go here
    http://www.frigidaire.com/manuals
    type in the correct model number in the box FTF530FS1
    download the wiring diagram and scroll down to "Motor Will Not run". Follow the instructions
    Yes, Jack is correct.
    Its likely the spin control board assembly thats bad.
    There is also a fuse on that spin control board, check it with a ohm meter to see if its good, should have continuity(0-1 ohm on your ohm meter).
    Here's the spin control board for your model you can order here:
    Part#134149220 is RepairClinic Item #1206430
    Spin control board assembly
    All parts come with a 365 day full refund, even if you installed them.
    In the bottom of your washer, you should have a tech. data sheet, it tells you what to check for when the tub is not turning if the fuse is good.
    But 90% of the time when the tub does not turn at all in wash or spin, then its the spin control board.
    For that test connector on your door latch switch use a voltage meter and Simply insert your black and red testing needles into the receptacle. If there is voltage during the spin cycle, this is bad. Replace your door lock and latch. If there is no voltage, the door lock is not your problem.
    You can order at this link:
    Door lock and switch assembly
    Jan 2011
    new york
    Jackofalltrades, I had trouble following the links. But thank you for the help.
    Jake, I found the tech sheet and test 5&6 for no voltage and had power from the test receptacle and had power. So the problems seems to be the door latch. I ordered one from the link you left me.
    Again, thanks for the help
    Ok, sounds good, keep us posted.
    Jan 2011
    new york
    Well, I put the switch in and still no go. I guess I'll be looking at the spin control board
    Ok, thats odd with the test you did in post #5 it pointed to a bad door switch.
    Yes, then the new motor spin control board should fix it.
    Keep us posted.
    Jan 2011
    new york
    I'm not really sure if its makes a difference in test results. When I pulled the Spin Control Board out a diode fell into my hand. It was cracked and had no continuity.
    Then yes, a new spin control board will fix it.
  1. FIXED: Frigidaire Dishwasher Er Error
    By enicholson in forum Frigidaire/Electrolux
    Last Post: December 4th, 2010, 02:51 PM
  2. [FIXED] Frigidaire Gas Oven & Broiler Not working
    By rdowler in forum Frigidaire/Tappan/Electrolux
    Last Post: August 30th, 2010, 12:42 AM
  3. [FIXED] Frigidaire broiler element Cooked?
    By handsometoo in forum Frigidaire/Tappan/Electrolux
    Last Post: December 3rd, 2009, 10:30 AM
  4. Please help with Frigidaire model numbers
    By Bruce Humphrey in forum Frigidaire/Electrolux
    Last Post: November 29th, 2007, 06:25 PM
  5. Frigidaire Double Wall Oven or Repair Existing GE Wall Unit
    By knittermom in forum Frigidaire/Electrolux Reviews
    Last Post: February 8th, 2007, 11:39 AM
