Results 1 to 2 of 2
Thread: Maytag washer squeaks.
    Jun 2010
    calgary
    Default Maytag washer squeaks.
    Model Number: MAV7200AWW
    Brand: Maytag
    Bought a used washer and dryer, from a couple that looked like they had cared for it. They had mentioned to me that it would make a squeak sound
    once when it quits spinning and once when it turns off. They said it developed the squeak shortly after they purchased ,hasn,t gotten any worse
    and I guess they just lived with it. What's wrong with it and is there any budget fix ups that can be done as it's not worth spending a lot of money to fix it. Any help would be appreciated.
    Thxs.
    Yes, you will need the Brake and Rotor Lining and Brake Stator. When I worked at Montgomery Ward in the 90's I was changing about 2 or 3 of these a month.
    The brake tool is a must to change these parts.
    The part number for the Brake and Rotor Lining is 21002010
    The part number for the Brake Stator is 35-6918
    You may also want to examine the condition if the Thrust bearing assembly. Check to make sure it doesn't show signs of excessive wear.
  1. LA4910 Maytag Dependicare Washer Problem
    By heartmd in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 4th, 2011, 12:29 PM
  2. Maytag Bravos Washer OL error
    By klehman in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 18th, 2010, 04:46 PM
  3. Maytag washer not spining-belts ok-motor ok
    By kam1996 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 26th, 2010, 01:12 AM
  4. Maytag mav7000aww Top loading washer loud clicking noise during spinning
    By alan509 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: September 23rd, 2007, 06:18 PM
  5. Maytag washer fills with water and then nothing.
    By g206276 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 14th, 2007, 05:54 PM
