Social Buttons
Results 1 to 4 of 4
Thread: furnace shuts off
    Feb 2011
    missouri
    Default furnace shuts off
    Model Number: gmp 100-3
    Brand: other
    Age: More than 10 years
    My janitrol furnace runs about 10 minutes and then the gas shuts down, the fan keeps running and after 2 minutes the ignitor comes back on, lights and cycles again for about the same time. I have replaced the flame sensor and the automatic limit switch inside the box. Any help would be appreciated.
    Feb 2011
    missouri
    Default added
    also when I bypasses the high limit switch in side the box--the furnace will run ok--something is tripping the switch, but what?
    Nov 2008
    Middle Island ,LI, NY
    A dirty filter or blower squirrel cage causes too much cycling. Your furnace will go off on high limit continuously because it is not getting enough airflow through the heat exchanger. The furnace goes off on high limit to keep from overheating the furnace and possibly causing a fire. This is why it is very important to keep those filters changed.
    A dirty restricted air conditioning evaporator coil causes restricted airflow that causes too much cycling. Make sure your coil is not stopped up on the underneath side. I usually have to take off the coil end plates and use a vacuum cleaner and coil cleaner to get all the lint and dirt off. Make sure you clean in the direction the coil fins are running. If you do not, it will bend the fins over and cause more restrictions
    Feb 2011
    missouri
    Thank You, I will try cleaning
  1. intercity furnace cycling 90 seconds
    By dmnspeedz in forum HVAC
    Last Post: February 22nd, 2013, 06:35 PM
  2. Replies: 4
    Last Post: December 31st, 2011, 12:57 PM
  3. [FIXED] York furnace blower motor hum
    By pmantis in forum HVAC
    Last Post: June 29th, 2010, 07:45 PM
  4. Shuts Down
    By cgueho in forum Sears Kenmore
    Last Post: September 8th, 2009, 05:59 PM
  5. Kenmore Electric dryer series 90 shuts off
    By tomkat in forum Sears Kenmore
    Last Post: September 30th, 2006, 07:52 AM
