Results 1 to 9 of 9
Thread: Whirlpool dishwasher mystery leak. Already replaced front seal. Confused
    Feb 2011
    Buffalo, NY
    Default Whirlpool dishwasher mystery leak. Already replaced front seal. Confused
    Model Number: GU2275XTVY
    First of all I would like to thank everyone on this site. I have been lurking for a long time but finally had a problem of my own develop.
    I have a whirlpool dishwasher that is 1 1/2 years old (out of warranty) and it developed a mystery leak from the front door. I can see water sitting in the bottom of the door and it sprays out the side a little bit. I already replaced the door seal and checked the front vent. Any other ideas?
    I know that these are prone to leaks. Thank you in advance.
    Apr 2009
    Check for a cracked spray arm
    Feb 2011
    Buffalo, NY
    I checked for a cracked spray arm and it looks good. There is also a spray arm under the top shelf and that looks good as well. Should I remove the plastic nut that holds the arm on to inspect it further? Would any other pictures help diagnose this issue?
    Apr 2009
    Ok sounds like your spray arms are correct, does your door catch have an adjustement screw? If you push in your door while your dishwasher is leaking(washing),, does it stop the leak?
    May 2011
    Midway, ky
    Default catfanatic100
    Did you find the problem? I have the same situation.
    - water splashing from under bottom left corner of door.
    - changed door seal.
    - inspected bottom door splash guard and cleaned.
    - water level is below heating element.
    - vent is clear.
    - ran without soap - no sudsing.
    - no visible signs of spray arm problem.
    - pump gasket seems in place.
    any suggestions?
    Sep 2011
    British Columbia
    Default One more option
    I had this problem of leaking i my westinghouse/inglis after I had eliminated the gasket, spray arm, latch etc. The Inglis parts man suggested one more option to check. The problem was that under the spray arm ( need to take it off) were screws ( about 6 or so) that had come loose. Tighten them up and I was fine
    Sep 2011
    British Columbia
    Default Leaking Dishwasher .... loose screws
    I have tried to add a picture to show where the loose screws are I described in the previous post
    Resize the picture to 850 or below then you can add it here.
    Feb 2013
    Virginia
    I am having the exact same issue as the original poster. Does not appear a solution was found. Any ideas?
  1. FIXED: Another Whirlpool Dishwasher won't drain
    By rickm in forum Whirlpool/Roper/Estate
    Last Post: January 26th, 2016, 04:46 PM
  2. Dishwasher leaking water at bottom of front door
    By Lighthouse Wife in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 24th, 2012, 07:50 AM
  3. Whirlpool Duet Washer - Water leak issue
    By soundjunkie in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 28th, 2012, 10:57 PM
  4. Whirlpool Dishwasher, fuse problem
    By Megz33 in forum Whirlpool/Roper/Estate
    Last Post: November 28th, 2005, 10:18 PM
  5. Whirlpool dishwasher door leak
    By jschneider in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 5th, 2005, 10:26 PM
