Results 1 to 10 of 12
Thread: Kenmore Elite: Water Filter Causing Loud Rattling Noise
    Feb 2011
    Oklahoma City, OK
    Default Kenmore Elite: Water Filter Causing Loud Rattling Noise
    Model Number: 106.56703500
    My refrigerator started making a very loud and rattling type of noise and we weren't sure where it was coming from. I removed the water filter from the base and it stopped immediately.
    I thought maybe the filter might just need replacing, so I got a new one and upon installing it, it immediately starting the loud rattling noise again.
    The sound is almost like a jack hammer, when the filter is in place the sound is there, when I remove the filter, no sound at all and water runs fine.
    Any clues what would be going wrong with my refrigerator now?
    Its your water filter housing valves that are possibly causing it, seen this happen before.
    You'll likely need a new filter housing.
    Here's the filter housing for your model, you can order it here:
    Manufacturer's Number: W10121138 is RepairClinic Item #1480816
    Feb 2011
    Oklahoma City, OK
    Thanks Jake.
    Do you know what has gone wrong with the current housing part that is causing this jack hammer sound, why it needs replaced?
    Thanks.
    Like I said, its possibly the valves inside that housing that have gone bad, and why? I have no clue why they go bad. Some do, some don't.
    Feb 2011
    Oklahoma City, OK
    Like I said, its the valves inside that housing that have gone bad, and why? I have no clue why they go bad. Some do, some don't.
    Well, just curious if I pull out the current one, if the valves are just clogged or calcified or something from maybe hard water running in there, if they can just be cleaned and not have to replace the entire part? Thats what I was getting at, but I don't even know how to take it out, so I guess the repair man will let me know. Thanks for your help Jake.
    Its easy to remove, just remove the kickplate and you will see how its mounted in there.
    Sure you can try to soak or clean it.
    Its #28 here:
    (click to enlarge)
    Feb 2011
    Oklahoma City, OK
    Well, the repair man came out, when I was gone, and my wife let him do the work.
    The invoice says...
    H/D Electronic Control W/T valve and hardware assembly - $148.99
    Total labor - $90.00
    Tax - $13.40
    Total - $252.39
    Not sure what all that is...? Hopefully they were honest.
    So it wasn't the filter housing?
    Thats very strange, because you said with the filter removed it wasn't making that noise.
    Was it the water inlet valve:
    Manufacturer part number W10159839 is RepairClinic item number 1389142
    Feb 2011
    Oklahoma City, OK
    I wasn't there to see what he pulled out, all I have is that info I typed from the invoice.
    Could this "Water Inlet Valve" be the same as the "H/D Electronic Control W/T Valve and Hardware Assembly" he put on the invoice?
    I'm just trusting he replaced the right part, as its working now and not making a noise.
    It didn't appear that he replaced the housing either. So this must be the part he replaced?
    Yes, thats what I'm thinking, because thats the only valve for the water flow that costs that much.
    So I guess I was wrong, but you have this new type of water inlet valve called a "smart valve" that I haven't run into as of yet on any of my service calls.
    Thanks for the update, glad its working good again.
  1. Kenmore Elite - Loud Grinding/Crackling Noise
    By dnobrn in forum Sears Kenmore
    Last Post: April 27th, 2014, 09:49 PM
  2. FIXED: Kenmore Elite Dryer makes loud noise and won't run
    By JSLayton in forum Sears Kenmore
    Last Post: November 17th, 2013, 12:27 AM
  3. loud rattling noise
    By wataugan in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: November 7th, 2010, 05:54 PM
  4. Replies: 1
    Last Post: June 1st, 2007, 09:04 PM
  5. Rattling Noise when water goes to ice maker
    By K_man in forum Sears Kenmore
    Last Post: February 12th, 2006, 02:57 PM
