Results 1 to 10 of 14
Thread: [FIXED] Jenn-Air JRSD209TW Side/Side Refer not cool
    Feb 2011
    jax beach fl
    Default [FIXED] Jenn-Air JRSD209TW Side/Side Refer not cool
    Model Number: JRSD209TW
    Brand: Jenn-Air
    Age: More than 10 years
    Refer side recently warm (50 degrees).
    Freezer side cold (0 degrees).
    Door switches and seals good.
    Compressor and fan are running.
    Coils are clean.
    Whazz next? Thanks!
    SundogJax
    Sounds like the air diffuser may be broken.
    Please check your model# again, that one didn't pull up.
    Help Me Find My Model Number - RepairClinic.com
    Feb 2011
    jax beach fl
    Default Jenn-Air JRSD209
    Appreciate the response Jake. Thanks!
    Holding the use & care manual in my hands - Jenn-Air JRSD209.
    Other model #s on the manual JRS229, JRSD2250, JRSD229, JRSD2460, JRSD2490, JRSD2790. Door-sticker says "JRSD209T 19.8CF). Built 1996.
    Inside A/C'd house at all times.
    Checked the freezer to refer damper - it's clear.
    Compressor and fan running. Coils clean. No ice build-up anywhere.
    Manually advanced defrost timer (mechanical not electronic)...Shuts off compressor...re-advanced so it's running. Lights work.
    Will multi-meter both temp control (PN 69614-3) and defrost timer (PN 68233-3, sticker {26se96aq00} this AM (borrow my amigo's meter).
    Guessing defrost - but I am just an amateur...but know beer is 55 degrees!
    Again - appreciate your guidance.
    - SundogJax -
    Feb 2011
    jax beach fl
    Default "jrsd209tw" JRSD209TW Parts
    Tried
    "jrsd209tw" JRSD209TW Parts in your SE and it popped positive.
    Yes that model# worked fine.
    Well this is an interesting issue, you've basically checked everything I would have if I was there at your house.
    If the air damper is open and clear you should be getting a good flow of cold air coming in from the freezer section.
    Feb 2011
    jax beach fl
    Default Deforist Timer failed the VOM test
    All open - non closed. Hate to troubleshoot with parts, but I will...ordering the part. Thanks. Let you know. Cold ice cream and warm beer. Yuk!
    The defrost timer just makes the defrost heater come on.
    Did you remove the back panel from inside the freezer to look at your evaporator coils to see if they have massive frost build up on them?
    That would definitely cause this issue.
    Here's the defrost timer for your model:
    Manufacturer's Number: 68233-3
    Feb 2011
    jax beach fl
    Default Defrost the Evap Coils
    Great pointer! Evap coils were solid ice... no clue why.
    Defrosted with hot water - cleaned up the freezer, reset freezer dampner to mid point and overall thermo to 8 0f 12. Gonna sleep on it. Already back to 50 in refer, freezer at 20 (1.5 hrs into re-cool).
    Not sure why evaps frozen solid... thinking heater and heater thermo?
    Defrost timer Manufacturer's Number: 68233-3 rolls around and turns the fans off - so perhaps its really working (even though the VOM test said BAD). That leads me to think bad heater (& perhaps heater thermo).
    Left alone, I would replace heater and heater thermo. Then try the defrost timer.
    Thoughts?
    Thank you for your assistance today. At $40/hr figure I have $280 in so far.
    Thanks Jake!
    I usually find the defrost heaters bad about 75% of the time, so I would ohm them first for continuity.
    Your defrost thermostat MUST be frosty to get a proper reading, normal would be 0-1 ohms.
    Make sure you unplug your refrigerator first.
    The defrost thermostat is #30 and the defrost heater assembly is #20 here:
    Here's the defrost heater for your model:
    Manufacturer's Number: 61001874
    Your defrost thermostat:
    Manufacturer's Number: 52085-29
  1. FIXED: Freezer cold, but Warm fridge side - not cooling? Air flow 101 - HELPFUL INFO!
    By PatrickM in forum Refrigerators & Freezers
    Last Post: November 29th, 2014, 12:30 PM
  2. Can Jenn Air Pro Series Range be converted?
    By wsnelms in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: May 26th, 2013, 09:42 AM
  3. Replies: 24
    Last Post: September 12th, 2008, 03:41 PM
  4. Replacing old Jenn Air cooktop and ovens
    By dibiaggio in forum Maytag/Jenn-Air Reviews
    Last Post: August 21st, 2007, 06:19 PM
  5. Jenn Air Downdraft Cooktop Replacement
    By mfrank2109 in forum Antique and Retro Appliance Chat
    Last Post: October 5th, 2006, 11:39 PM
