Results 1 to 6 of 6
Thread: Whirlpool F28
    Feb 2011
    NM
    Default Whirlpool F28
    Model Number: WFW8300SW00
    WFW8300SW00
    Guys,
    I have a Whirlpool Duet front loader that has finally quit and is showing a code of F28.
    The machine has been giving me problems for awhile now. It would run and then stop if the load became to heavy. So we reduced our loads (my wife gets carried away sometimes). This helped for awhile but the problem started ocurring more often. The machine would not run or stop mid-cycle and we would have to unplug the machine, manually unlock the door and wait a little bit. Sometimes there wouldn't be an error code for a while.
    I have looked at the options on the internet for awhile and I have tried them out on the machine but to no avail.
    All the links for manuals and such provided by all these sources seem not to work.
    Any ideas?
    Is it a MCU & CCU? Or is it time for a new washer?
    The F28 code is a comm failure between the MCU and the CCU. First, check the wiring harnes connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
    Yes, I read a couple past members that diagnosed it as the MCU being the cause more than the CCU.
    So you can order the MCU and/or the CCU, then I'd install the MCU first to see if that fixes it.
    Here's the CCU for your model:
    Whirlpool W10205839 Electronic Control
    Here's the MCU for your model:
    Motor Control Board W10197864 Order now for same day shipping. 365 day return policy. RepairClinic.com
    We have a special program here, all parts you order from our links we post are returnable within 365 days for a FULL refund if they don't fix the problem.
    Feb 2011
    NM
    Thanks for that info. After the unit had been off awhile I plugged it back in and changed to the delicate option and its been working so far. Do you think it is still the MCU or other?
    Its really hard to tell or not if its the MCU, I'd take your MCU out and look at it for possible burned spots on the board first.
    Feb 2011
    NM
    Glad to help.
  1. FIXED: Whirlpool duet sport error code F28
    By nfirman in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 11th, 2015, 11:05 PM
  2. F21, F28 fault codes
    By divertx in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: May 16th, 2010, 01:17 PM
  3. Whirlpool Duet F11 error code, feedback requested
    By Dutch08 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 21st, 2010, 10:12 PM
  4. Whirlpool Gold
    By ecom in forum Whirlpool Reviews
    Last Post: November 12th, 2009, 08:56 AM
  5. Whirlpool du1148xtpqa dishwasher sensing won't work
    By dmello1284 in forum Whirlpool/Roper/Estate
    Last Post: August 22nd, 2007, 12:49 PM
