Results 1 to 4 of 4
Thread: Oven wont start
    Mar 2011
    USA
    Default Oven wont start
    Model Number: WFE366LVB
    Hello~
    I have a Whirlpool Accubake Electric Oven.
    The top burners work fine as does the control panel.
    The oven "bake" and "broil" and "warm" functions do not work...
    Any help would be appreciated greatly.
    Sounds like the clock oven control board may have gone bad.
    Do you have a volt meter to check for 240 volts at those elements?
    Mar 2011
    USA
    Thanks for the reply Jake.
    I do not have a volt meter.
    I can try to borrow one from a guy at work...
    How do I go about checking it?
    You just put both volt meter leads on both element terminals at the same time and it should read 240 volts.
    So for the bake(lower element) touch your volt meter probes on both ends of those two bake element terminals while its on the bake cycle.
  1. FIXED: Error codes on built-in double oven model # RBD306PDQ14
    By spthomas in forum Whirlpool/Roper
    Last Post: November 11th, 2013, 07:31 AM
  2. Adjusting Air Shutter for Oven gas valve on Hot Start Ignition Oven
    By searcherrr in forum Frigidaire/Tappan/Electrolux
    Last Post: February 21st, 2011, 12:53 AM
  3. FIXED: GE Profile Dual oven bottom won't start
    By mdbonnie in forum GE/Hotpoint
    Last Post: December 18th, 2010, 01:06 PM
  4. Whirlpool oven start and minute buttons do not work?
    By redline808 in forum Whirlpool/Roper
    Last Post: October 6th, 2009, 06:59 PM
  5. Maytag Gas Oven won't start without help...
    By gt2847c in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: July 13th, 2008, 10:32 AM
