Results 1 to 5 of 5
Thread: Admiral Dryer will not start
    Mar 2011
    Roberts
    Default Admiral Dryer will not start
    Model Number: ade7000ayw
    Brand: Admiral
    My dryer quit working today. It will not start and light will not come on. I can hear the timer ticking. I tried to turning off the breaker and turning back on. Checked wires. What could be causing the problem
    Mar 2011
    Roberts
    Default The fuse inside the dryer
    Would the fuse cause the light and the dryer not to work. I removed the fuse should it make a rattle noise inside?
    Aug 2006
    NY
    jump the wires to the fuse.If the dryer starts the fuse is bad. For legal purposes I must advise you that jumping the fuse is only for temporary test purposes ONLY, you must assume all risks by doing so
    Mar 2011
    Roberts
    Default Fuse
    Where is the fuse and how do you jump it. I removed what I thought was the fuse now I am not sure.
    Here's the thermal fuse kit for your model:
    Manufacturer part#LA-1053 is RepairClinic item#3344
    Unplug your dryer first, heres a help link:
    thermal fuse LA1053, magic chef, norge, performa dryer thermal fuse kit for gas and electric dryers
    Access help courtesy of www.applianceaid.com
    Get the top up on the dryer. Service the heater, high limit, and thermal fuse from here with the top up. Check the heater, high limit thermostat, and the thermal fuse with an ohm meter. All should show continuity. Remember to always remove the wires from the part you are checking with an ohm meter.Next picture is the heater. It is located on the left rear of the drum in a housing. The thermal fuse and the high limit thermostat are also located here. The thermal fuse on this dryer shuts the motor down when it is blown.
    Or as Jack said just take the thermal fuse wires off and hook the wire terminals together and plug your dryer in and start it and see if it runs.
  1. Kemore Dryer - will not start
    By Mr. Big 173rd ABN in forum Sears Kenmore
    Last Post: December 21st, 2010, 09:39 PM
  2. Dryer won't start, could it be motor?
    By dharmon23 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: October 2nd, 2009, 03:11 PM
  3. Frigidaire Dryer won't start without a "push"
    By web in forum Frigidaire/Electrolux
    Last Post: October 15th, 2007, 08:30 AM
  4. Whirlpool dryer will not start...
    By STS1SS in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: August 24th, 2007, 11:56 PM
  5. Whirlpool Dryer won't start Model#LEC6646AQ0
    By birdcam in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: June 30th, 2007, 01:12 AM
