Results 1 to 10 of 10
Thread: [FIXED] Kenmore gas stovetop not lighting
    Mar 2011
    IDAHO
    Default [FIXED] Kenmore gas stovetop not lighting
    Model Number: 362.75575691
    Age: More than 10 years
    I have a Kenmore gas stove that the top burners are having a hard time to light off.When i put the knob to lite the igniters are clicking but no flameup.I have checked all the small orfaces in the burners and every one is clean.I can see spark from the igniters and smell gas but no lite.Thought it might be spark module not putting enough juice out.Any ideas would be helpful. Thanks
    The spark module may have a weak coil, which is not providing sufficient voltage to ignite the gas BURNERS.
    I've chaged a few in my 20+ years of being an appliance tech. and that fixed it on the ones I went out on.
    Unplug your range before changing it, its usually located in the very back of your range, behind the back access panel.
    Here's the spark module for your model you can order here:
    Manufacturer's Number: WB13K25
    Mar 2011
    IDAHO
    Jake, Thanks for the quick reply! That is where i am at right now.I have been watching the igniters and they fade away like they are losing spark.I think that is the problem rather than a bad igniter.I think the coil is losing power. Thanks again i will get one ordered. Wade
    Ok Wade, yes I agree.
    Keep us posted.
    Mar 2011
    IDAHO
    Jake,I got parts ordered from your supplier here.I had to order the 2 lf/rf Gas Burner Lines because when i lifted the range top to check everything out it kinked the 2 front lines and when i put the top down it cracked them.I know now to pull the 4 screws from the burners before i lift the range top off.Must be a reason why they only have the 2 front lines listed in their parts listing,because that happens periodically.
    Yes, that is odd.
    Did you locate the spark module? Usually its in the very back of the range behind the back access panel.
    Mar 2011
    IDAHO
    Jake, Yep, That was very easy to locate and shoud have the replacement today.Now i have to wait a couple of days for the burner lines.It's the pit's a 70.00 fix now cost's 150.00, With me doin the labor.I see the new lines have a different bend config which should be better for not kinking.Thanks for your help! I will let ya know how it all turns out. Wade
    Ok Wade sounds good, keep us posted.
    Mar 2011
    IDAHO
    Jake, Just installed the new gas tube lines and everthing works like new! The spark module was the problem and the new one fixed it! Thanks for you expertise! Wade
    Excellent Wade, good job.
  1. [FIXED] Maytag MGS5770ADB Gas Oven Not Lighting
    By GJKeating in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 31st, 2012, 01:38 PM
  2. Kenmore Elite 110 Gas Dryer - Burnt Smell Runs Hot
    By Krawlspace in forum Sears Kenmore
    Last Post: June 12th, 2008, 11:21 AM
  3. Kenmore gas oven slow to heat up
    By t7044wa in forum Sears Kenmore
    Last Post: November 6th, 2007, 05:43 PM
  4. Kenmore 70 series gas Dryer not heating right
    By pflowers in forum Sears Kenmore
    Last Post: February 12th, 2007, 09:14 PM
  5. Whirlpool super capacity 465 gas oven not lighting
    By magna8385 in forum Whirlpool/Roper
    Last Post: February 6th, 2007, 05:36 PM
