Results 1 to 6 of 6
Thread: Water filter leaks
    Apr 2005
    Kansas City
    Default Water filter leaks
    Model Number: glrs267zdb4
    Brand: Frigidaire
    Customer reports replacing the water filter and now it leaks. I had them inspect the o rings but are reported to appear ok. Now what? I know the Frig. units have had this problem...
    Yes, thats true.
    Its likely the filter base thats bad making it leak. Seen many myself and replaced the base and all was fine.
    The filter base is #139 here, its the part where the filter pushes into:
    http://c.searspartsdirect.com/lis_pn...5192-00005.png
    Here's the filter base#139
    Manufacturer part number 240396002 is RepairClinic item number 1056733
    240396002
    Apr 2005
    Kansas City
    More info from the customer. When it makes ice it sprays from the filter area...?
    Ok, you mean when the ice maker fills it sprays from the filter area?
    Thats an odd one, never seen that happen before.
    But its likely still the filter base you will need to change.
    Apr 2005
    Kansas City
    Updated info. I was over there this morning. I had dropped the whole control assembly and let it hand down in order to see where it was leaking. After several tests I determined that on the right side filter, where the clear plastic filter housing was glued to the white part at the rear, there was a hair line crack going about 3/4 or the way around the cylinder. Under pressure water was forced out through the crack. I wonder what caused the crack? Customer is picking up a new filter . Hopefully he can find his receipt from the other one.
    Oh, yes I've seen that happen once before myself, don't know that cause, but the new filter will fix it.
    Here's the filter for this model:
    Manufacturer's Number: WF2CB
    WF2CB
  1. Kenmore 106.56532400 Leaks When Filter Removed
    By ch3712 in forum Sears Kenmore
    Last Post: November 18th, 2010, 12:09 PM
  2. Replies: 1
    Last Post: October 16th, 2010, 10:24 PM
  3. Replies: 3
    Last Post: July 28th, 2008, 04:02 PM
  4. LG 27950 fridge; water filter leaks
    By mike1812 in forum LG
    Last Post: November 10th, 2007, 09:55 AM
  5. Water Filter Bypass without a Bypass?
    By yuzow in forum Frigidaire/Electrolux
    Last Post: January 5th, 2006, 11:47 AM
