Results 1 to 2 of 2
Thread: Help! I need a Jenn-Air JDB1270AWY service manual
    Apr 2011
    los angles
    Default Help! I need a Jenn-Air JDB1270AWY service manual
    Model Number: JDB1270AWY
    Brand: Jenn-Air
    Hello,
    My dishwasher is making that grinding / whining sound others have written about. I'm thinking there may be something stuck - as sometime it's can be quiet. Does any one have a service manual pdf? I would love to try and fix it.
    W3ndy
    Hi W3ndy,
    Here it is: www.applianceblog.com/manuals/16021814.pdf
    Its possibly either your chopper blade is bad and came out of place or your impeller is bad, or worst case the motor went out.
    Or even seeds can get stuck in the wash impeller or chopper blade and cause this.
    Here's the diagram of your pump and motor assembly: Parts for Jenn-Air JDB1270AWY: Pump & Motor Parts
    You'll need to take off numbers 1,2,4,5,6,7 then you will be at your metal chopper blade, thats likely were its broken or out of place, possibly a seed or something hard that down in there and broke it.
    Also check your impeller#6 to make sure the plastic isn't chewed up either.
    Here's the impeller chopper blade assembly for your model:
    6-919539 Motor Seal Kit
    Here's the motor assembly for your model:
    6-919922 Wash Motor
    Here's the wash impeller#6:
    99002659 Wash Impeller Assembly
  1. FIXED: Freezer cold, but Warm fridge side - not cooling? Air flow 101 - HELPFUL INFO!
    By PatrickM in forum Refrigerators & Freezers
    Last Post: November 29th, 2014, 12:30 PM
  2. Service Manual for Ruud Air Handler
    By drooplug in forum HVAC
    Last Post: July 16th, 2010, 04:20 PM
  3. jenn air 47600 need user guide manual
    By toby in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 24th, 2007, 06:40 AM
  4. Jenn Air model W188 user manual?
    By randy lake murray in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: March 8th, 2007, 06:32 AM
  5. Jenn Air Downdraft Cooktop Replacement
    By mfrank2109 in forum Antique and Retro Appliance Chat
    Last Post: October 5th, 2006, 11:39 PM
