Results 1 to 8 of 8
Thread: Kenmore washer
    May 2011
    Georgia
    Default Kenmore washer
    Model Number: 110.47791700
    I have a Kenmore Elite Smart Wash Steam Care Quiet Pak 9 HE 5T Steam front loader washer.I'm having a problem my washer is putting up codes when i try to wash. The code is SUD then another code comes up F35. Could you tell me what is wrong?
    Its the water level switch(aka pressure switch) thats bad. Take the top panel off, should be 3 hex screws in the back that hold that panel on, then you will see it on the right side standing in front of your washer. Its orange and brown in color.
    Here's the one for this model you can order here:
    Manufacturer part number W10156252 is RepairClinic item number 1454549
    Make sure you ALWAYS use HE type brand detergent, non-HE detergent will cause this to break and throw the F35.
    May 2011
    Georgia
    Thankyou very much for replying to my problem. I have just ordered that part it will be in 2 days.
    Sounds good, keep us posted.
    May 2011
    Georgia
    I'm having another problem with this same washer. It first started saying SUD then the code come up F21. Can you tell me what this code means.
    Sounds like your water pump filter is clogged.
    Unplug the Machine
    Remove Three Torx (hex heads) screws on front bottom of machine. Slighty lift the panel and pull the bottom towards you. Pump is right in middle in front of you.
    Unscrew the pump handle with your hand and the filter will pull out, get something to catch the water thats left in it in.
    Here's the water pump for your model:
    Manufacturer's Number: 280187
    May 2011
    Georgia
    Thankyou so very much. I got to say you are one smart man. My husband came home after work and read your message and fixed my washer.
    Excellent, glad to hear that.
  1. FIXED: Kenmore washer won't spin out all water from clothes model # 110.15842400
    By Lewis-the-dog in forum Sears Kenmore
    Last Post: January 22nd, 2012, 05:09 PM
  2. Kenmore Heavy Duty 70 Washer unbalanced - toast?
    By top_five in forum Sears Kenmore
    Last Post: January 9th, 2008, 12:30 PM
  3. Please diagnose my problem....Kenmore washer
    By Stinger44 in forum Sears Kenmore
    Last Post: December 7th, 2007, 07:57 PM
  4. Kenmore 70 series washer unbalanced
    By gerifalte in forum Sears Kenmore
    Last Post: November 1st, 2006, 02:31 PM
  5. Kenmore washer intermittent burning smell
    By mvmartin in forum Sears Kenmore
    Last Post: February 10th, 2006, 01:40 AM
