Results 1 to 2 of 2
Thread: Kenmore Coldspot - not getting cold
    May 2007
    Texas
    Default Kenmore Coldspot - not getting cold
    Model Number: 106.9712610
    Age: More than 10 years
    Refrigerator was running fine. Our electricity went out a couple times during the night. The next day, I noticed the refrig wasn't cooling anymore. When I turn it on, I can hear the fan running, but I don't hear the compressor starting. Is there a reset/relay button for the compressor? What else can I check or do to figure out what's wrong.
    Thanks for your help.
    CM
    Hi CM,
    It may be the compressor start relay, its mounted on the side of the compressor.
    You will need a ohm meter to ohm it for continuity, Unplug your refrigerator first before removing and testing it. If after you remove it shake it, if it rattles inside its definitely bad.
    Here's that relay for your model you can order here if needed:
    Manufacturer's Number: 2262181
    2262181
  1. Replies: 6
    Last Post: May 7th, 2011, 07:32 PM
  2. Replies: 11
    Last Post: June 2nd, 2010, 08:41 AM
  3. Kenmore Coldspot Side-by-Side Freezer Too Cold
    By applebug in forum Sears Kenmore
    Last Post: December 9th, 2009, 07:31 PM
  4. FIXED: Kenmore ColdSpot 106.55522400 Freezer Cold, Fridge Warm
    By jacuze01 in forum Sears Kenmore
    Last Post: September 28th, 2008, 12:47 AM
  5. Replies: 1
    Last Post: May 10th, 2007, 12:15 PM
