Results 1 to 5 of 5
Thread: Whirlpool Duet Washer Will Not Power Up
    Apr 2010
    Ft. Lauderdale
    Default Whirlpool Duet Washer Will Not Power Up
    Model Number: GHW9150PW2
    Washer does not power up. No display. Troubleshooting guide says to verify power at receptacle. I have 120vac. Guide says to plug unit in and listen for audible click from CCU. No click. Guide says replace CCU. I replace p/n 8182695 CCU with new unit. Still no audible click, no display. There is an electrical filter inline before the CCU. It checks good per the troubleshooting guide. Are bad parts from stock common? What else could be the problem?
    Apr 2010
    Ft. Lauderdale
    WOW!!! Put this one into the memory banks for this model washer. I was reading other posts with the same problem as mine. Another poster had found a bad wire on the grey cable the runs from the CCU to the control panel from laying on the drum. Guess what? Same here. I fixed the wire and everything works as described. Now I gotta try and get my money back for the CCU.
    Excellent, good job Billy.
    Where did you buy the CCU from?
    Apr 2010
    Ft. Lauderdale
    I bought the CCU from Marcone. There is a local store here. It was a little more expensive that repairclinic.com, but it was local. I did get my money back today.
    Ok, Even though you already installed it? They gave you a full refund?
    If so that sounds good. Most local appliance parts stores won't.
  1. Whirlpool Duet Washer - Water leak issue
    By soundjunkie in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: April 28th, 2012, 10:57 PM
  2. FIXED: whirlpool duet steam won't power on... no lights
    By rickerra in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: March 3rd, 2011, 08:43 PM
  3. Whirlpool Duet Washer Has No Power
    By misterbox83 in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 31st, 2011, 01:27 PM
  4. F20 error on BRAND NEW Whirlpool Duet Steam Washer
    By mikemilw in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: January 22nd, 2008, 09:16 AM
  5. Whirlpool Duet GHW9100LW - No Power Condition
    By 450HP in forum Whirlpool/KitchenAid/Roper/Estate
    Last Post: December 18th, 2006, 11:30 AM
