Results 1 to 5 of 5
Thread: Lock Door Message
    Dec 2005
    illinois
    Default Lock Door Message
    I have a Kenmore 362.75990000 Gas Range. The message "Lock Door" flashes on the display, even though I did not activate the cleaning feature. I am unable to clear this message, or operate the cleaning feature to clear it. In addition, I'm unable to use the oven. No New Year's Day pie for me. Any help will be appreciated!
    Did you try to turn the breaker off to it for about 2 minutes? Sometimes that will reset it.
    Dec 2005
    illinois
    I didn't turn the house breaker off. I didi unplug it for a few minutes, but no results. Is there a reset button in the oven somewhere? According to the schematics this message is displayed when the oven heats to 600 + degrees.
    No, there's not a reset button in the range. Its either the oven sensor, control board thats giving you this problem, if you wanted to try to fix it yourself, here's a link that should help:
    http://www.applianceaid.com/grange.html
    Oct 2005
    Wichita Falls, Texas USA
    This range was made by GE, I do not find a fault code for Lock Door for this brand, others did show the problem to be a defective door lock assy., but do not go by that for a sure fix..you need to find the tech sheet in your range to see what this means for your unit...
  1. Door Lock and air blower are jammed
    By hopemick in forum Sears Kenmore
    Last Post: June 8th, 2007, 01:00 AM
  2. Kenmore 417.41042000 Door Lock Lites but nothing else happens
    By cmoyer.work@gmail.com in forum Sears Kenmore
    Last Post: May 29th, 2007, 11:39 AM
  3. Lock Mechanism Melts After Cleaning Cycle
    By KC2 in forum Whirlpool/Roper
    Last Post: March 7th, 2007, 11:17 AM
  4. Maytag 4000 Lock not disengaging.
    By michael_lambert in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: October 19th, 2006, 12:40 AM
  5. Child Lock Light
    By Terry F in forum KitchenAid
    Last Post: December 15th, 2005, 09:30 AM
