Results 1 to 4 of 4
Thread: Kenmore 80 series gas dryer won't start
    May 2011
    michigan
    Default Kenmore 80 series gas dryer won't start
    Model Number: 110.76842501
    My Kenmore 80 series gas dryer won't start. Open door light is out , ,Power to unit is good , nothing (no fuses) tripped,it is not the belt belt is good,what should I be looking for?? cycle is set,push starter,nothing.....in past 3 yrs I have replaced cycling thermostat,thermal overload,gas burner coil kit,put on new vent tube(aluminum),vent is clean,not stuffed with lint, ......any tips would be appreciated!
    I say to check your door switch for continuity first, It could of given out completely which would cause the dryer not to start at all.
    Its easy to get to the door switch, here's a help link to show you, read paragraph 2 here:
    http://www.applianceaid.com/wpdryer_...tml#full_front
    Remove the door switch plastic electrical connector and put your volt/ohm meter on the ohm setting 200 and put your meter leads on both the door switch electrical terminals and see if it reads 0-1 ohm with the lever on it pushed in.
    If no reading at all, then its bad.
    Here's the door switch for your model:
    Manufacturer's Number: 3406107 is RepairClinic Item #528948
    May 2011
    michigan
    could it also be a fuse? in back above blower motor?
    No, on gas dryers if the fuse blows it will still run but just won't heat.
  1. Replies: 10
    Last Post: November 7th, 2011, 03:25 PM
  2. Replies: 6
    Last Post: May 16th, 2011, 03:53 AM
  3. Kenmore Series 80 dryer won't start
    By m302650 in forum Sears Kenmore
    Last Post: December 5th, 2009, 12:48 AM
  4. kenmore series 70 gas dryer
    By dsus4 in forum Sears Kenmore
    Last Post: February 26th, 2007, 07:44 PM
  5. Kenmore series 70 wont start
    By cefox01 in forum Sears Kenmore
    Last Post: April 16th, 2006, 04:53 PM
