Results 1 to 2 of 2
Thread: Ice formation in the bottom of friz frequently
    May 2011
    cary,nc
    Default Ice formation in the bottom of friz frequently
    Model Number: 795.77556600
    Ice is forming once a week under the freezer (in the bottom of friz). I had to chisel out the ice and some times water is also leaking on to the floor. Cleaned the back of friz with vacuum but no use. Also the front temperature display is showing 88 instead of actual temperature intermittently and making a different sound ( 3 beeps..) when door is closed. Not sure what to do about it. Thanks in advance for your comments.
    Thanks, mkbobba
    Hi mkbobba,
    It sounds like your defrost drain hole is clogged and not letting defrost water down the drain line to your drip pan underneath your refrigerator.
    I haven't worked on these models yet, but usually you just take the back panel off from inside your freezer, then you will see the defrost drain trough under your evaporator coils. Just use a hair dryer and hot water to melt the ice and clear the hole.
    I use a evaporator cooler spider snake:
    http://www.azpartsmaster.com/Products/Cooler-Spider-Snake__CLR4690.aspx
    They are used basically in Arizona to clean out the water pump tubes that run to the cooler pads.
    I don't know if they would sell them in your area, but if you go to your local hardware store, they should have something similar to run down your drain hole to clean it completely out.
  1. FFU14FC4CW5 ice on inside bottom of unit.
    By Pontihog in forum Frigidaire/Electrolux
    Last Post: March 26th, 2011, 02:26 PM
  2. Kenmore Ice stopped and ice collecting at bottom
    By robertmagness in forum Sears Kenmore
    Last Post: October 12th, 2009, 01:28 AM
  3. Ice Maker 106.2198597 Overflow
    By agodwin in forum Sears Kenmore
    Last Post: May 5th, 2009, 04:09 PM
  4. Complete Ice Maker Assembly - For In-Door Ice Models
    By Jake in forum Refrigerators & Freezers
    Last Post: April 29th, 2008, 12:56 AM
  5. Kenmore Elite Ice Spills in Bottom Freezer
    By chemjaneer in forum Sears Kenmore
    Last Post: March 8th, 2007, 10:29 PM
