Results 1 to 6 of 6
Thread: Jenn-Air range not holding temperature
    Jan 2006
    Richmond, VA
    Question Jenn-Air range not holding temperature
    I think I previously posted this in the wrong place. Sorry.
    I have a brand new Jenn-Air downdraft range model JES9860AAB. I purchased the range in October after my 21 year old Jenn-Air finally bit the dust! This new oven just does not heat properly. My baked goods take at least 25% longer to cook, (not shorter). Nothing browns properly. The temperature seems to be erratic. I set the oven for 350. The oven preheats to 350 and then drops to 285 or so before beginning to climb again. The repair technician told me that Maytag says it is normal for a Jenn-Air oven to drop 60 degrees or so. My old oven didn't do this. As a seasoned baker, I can tell you that no one who cooks seriously wants an oven that behaves like this. Sometimes the oven temperature is perfect. Sometimes, it spikes to 500 degrees or so; mostly it is runs on the cool side. The only way to keep constant heat in the oven is to put ceramic tiles in my oven and preheat for about 90 minutes.
    My service technician has a new circuit board on order. If that doesn't fix it, what are my options?
    Help!!
    Well, I know for a fact its NOT normal for the temp. to drop 60 degrees or so.
    That control board should fix it, but if it doesn't you will need a new sensor as well.
    Jan 2006
    Richmond, VA
    Thanks for the reply. I have printed this out and will give it to my service technician when he installs my new circuit board.
    Simple question. How much should an oven vary in temperature from the target temperature when the oven is fully preheated? What would you consider acceptable?
    Nancy
    It varies to some extent but it shouldn't more than 20 degrees off either way, high or low from the set temperature.
    Jan 2006
    Richmond, VA
    Again, many thanks.
    Glad to help.
  1. Jenn Air range JGR8750ADW
    By sadiedog1 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: February 11th, 2007, 06:05 PM
  2. Problem with Jenn air down draft slide in range.
    By jerr462 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: January 10th, 2007, 12:36 AM
  3. Jenn Air Wall Oven With Fault Code 1
    By AFH in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: November 3rd, 2006, 12:52 PM
  4. Jenn Air Downdraft Cooktop Replacement
    By mfrank2109 in forum Antique and Retro Appliance Chat
    Last Post: October 6th, 2006, 12:39 AM
  5. Frigidaire Double Oven not holding temperature
    By wswan in forum Frigidaire/Tappan/Electrolux
    Last Post: May 26th, 2006, 12:41 PM
