Results 1 to 10 of 10
Thread: GE Profile refrigerator too cold and freezer too warm
    Jun 2011
    Virginia
    Default GE Profile refrigerator too cold and freezer too warm
    Model Number: PDS22SFSLSS
    Brand: GE
    I have a GE Profile top refrigerator/bottom freezer model #PDS22SFSLSS. I have set the fridge portion on the highest temp possible (47) and the temp still stays in the 20's and freezes everything. On the other hand, the freezer stays too warm (teens). When you open the fridge, the metal portion up front that seperates the fridge and freezer is extremely hot to the touch. I have removed the bottom back panel to check the condenser fan motor as I have seen suggested on many other threads. The fan was not moving and covered in dust. When the fan was touched, the fan did start to move, but not very fast and has since stopped on it's own. I cleaned and vacumed out all of the dust. The fan will only move now when started by hand and will then stop shortly after. I have placed a small fan behind the fridge and have it aimed at the coils and am waiting now to see if the temp changes. Also, I thought I saw that the coils should be covered in frost??? Is that right? Because mine are not. Is this a fan motor issue or a control board issue? I have seen similar posts showing it couls be either.
    Jun 2011
    Virginia
    Default Update
    After the fan blowing on the coils for 2 hours the temp in the freezer has dropped from 9 degrees to 4 degrees. So that's going the right direction but the fridge is still getting cooler. The temp in the fridge has gone from 23 degrees to 21 degrees. But, the metal piece in the front that seperates the fridge from the freezer is no longer hot.
    Jun 2011
    Virginia
    Question Yet another update
    I guess I should have waited a bit longer before posting the last update. It's been about 4 1/2 hours now since I've had the fan blowing on the, I guess what you call, coils and now things seem to be evening out in the fridge and freezer. Still not hot to the touch and now the fridge is up to around 30 degrees! Any ideas or suggestions?
    Sounds like a faulty motherboard.
    Now here's where it gets weird, you should be getting 12-15 volts DC at the condenser fan motor, We've have had a couple members say that they were getting 13 volts DC and they replaced the condenser fan motor, but that didn't fix it, it was the motherboard that fixed it.
    Here's the motherboard for your model you can order here:
    Manufacturer part number WR55X10942 is RepairClinic item number 1531075
    WR55X10942
    Jun 2011
    Virginia
    Thanks so much for the reply. I am going to go ahead and order the motherboard today. I am not at all questioning your expertise but out of curiousity, what makes you think it's the motherboard? I have had the fan blowing on the back for 4 days now and the temps are both staying in the correct range and the metal piece is no longer hot. Is it the motherboard that's not "telling" the fan to run? Thanks again!
    Well, GE had many issues with the motherboard as you can see from all the threads and posts other members have posted.
    Your exactly correct.
    Order the new motherboard and you should be good to go.
    Jun 2011
    Virginia
    Already have it coming this way. I'll let you know how it goes. Thanks for all the help.
    Ok, sounds good.
    Jun 2011
    Virginia
    Well, I thought things were going good but since yesterday, not so much. :-( We installed the new control board on Sunday and up until yesterday the temps seemed to be staying in the correct range. When the control board was first installed, the fan started turning immediately. However, yesterday the temp started dropping in the fridge to the same levels as before (20's) and it is still that way today. I have the fridge set to 42. The only difference from before is that the metal part separating the fridge and freezer is not hot this time. At least not yet. Is the fan motor bad too? Or do you think the fan motor is bad and not the control board? Thanks!
    Ok, Sounds like the motherboard fixed the condenser fan motor in the back of your refrigerator, but how is the fan running in the freezer? Can you hear it running when you open the freezer door? If not, push the freezer door light switch and see if it starts running.
    Since its still in the 20's in the refrigerator section that indicates the thermistor in the refrigerator section next to your top air damper may be the fault of that.
    First test the thermistor, should be about 16.3 K ohms. Shawn has a good page that shows you how here: Testing A Refrigerator Thermistor On A GE Refrigerator
    This page will also help GE Refrigerator Repair Guide
    Thermistor WR55X10025 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Watch this video:
  1. FIXED: Freezer cold, but Warm fridge side - not cooling? Air flow 101 - HELPFUL INFO!
    By PatrickM in forum Refrigerators & Freezers
    Last Post: November 29th, 2014, 12:30 PM
  2. GE Profile fridge warm room temp, freezer extra cold
    By Intrigued in forum GE/Hotpoint
    Last Post: May 24th, 2011, 11:39 AM
  3. [FIXED] Magic Chef Side-by-Side Freezer cold but Refrigerator side warm
    By k2bzee6 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: August 18th, 2010, 11:25 AM
  4. GE Profile Freezer not getting cold enough
    By bonsainut in forum GE/Hotpoint
    Last Post: May 10th, 2010, 11:16 AM
  5. GE Profile Fridge. Cold Freezer. Warm Fridge
    By rcdr in forum GE/Hotpoint
    Last Post: April 3rd, 2008, 10:27 PM
Tags for this Thread
