Results 1 to 10 of 15
Thread: Kenmore Limited Edition 10 Gas Water Heater Leaking From Bottom
    May 2011
    atlanta
    Default Kenmore Limited Edition 10 Gas Water Heater Leaking From Bottom
    Model Number: 153.334476
    Just walked in the kitchen and found a puddle underneath the hot water heater. Looks like it's probably dead and needs to be replaced. Found on the bottom where it's leaking (just dripping now), so put a cooking tray there to collect the water. What's the best way to prevent the leak from becoming a larger issue? Should I turn it off? Turn it off and use up all the hot water to try and empty the tank? Thanks!
    Jul 2006
    Mr. icehouse is the hot water heater guru but I'm pretty sure there is a hose connection on the bottom for draining it. The best way to prevent the leak from becomming a larger issue is to replace the unit as soon as possible. I understand AO Smith is a good one.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    May 2011
    atlanta
    Thanks. I didn't see anything along the bottom. Just one closer to the top by the temperature/pressure relief valve. Hmmmm... We ended up putting a cookie tray under where it's dripping. That at least stopped the water from getting all over the floor. Just need to empty the tray every 4 hours or so. Last night drained it at midnight, then woke up at 4 to empty it again before doing so again this morning. Luckily my wife only has to work from 9-12 today, so she can keep emptying it until the plumber comes this evening.
    I also wanted to turn it off, but couldn't get the gas switch into the off position. I can turn it to the 'pilot' position, but not to the 'off' position. Oh well. Hopefully everything works out until this evening. Thanks again!
    Nov 2008
    Middle Island ,LI, NY
    http://www.searspartsdirect.com/part...dMod=153334476
    #4 is the drain valve you need to connect a garden hose to this. Shut off cold water inlet, open drain, open hot water faucet on sink or tub furthest from heater (speeds up the empting).
    Retired US Army Refrigeration Specialist
    Retired NYC Board of ED Refrigeration Teacher
    HVAC/R and Building Maintenance Instructor
    NATE Certified Proctor
    Nov 2008
    Thumbs up Fyi
    About AO Smith Water Heaters Manufacturer
    We will introduce you a company that is a leader in water heating industry, AO Smith Water Heating Company and their popular AO Smith water heatersmodels. A O Smith is in the heating business for almost 70 years, and it is well known for the quality and innovation in energy efficiency and tank protection.
    Glass lining is the A.O. Smith patented process, designed many years ago to protect water tank heaters from corrosion; it is now a standard in the water heating industry.
    A.O. Smith also owns several popular brands of hot water heaters that you probably had chance to see or read about:
    • State
    • Reliance
    • Maytag
    • American
    • GSW
    • John Wood
    May 2011
    atlanta
    Hmmm. So it looks like the drain is just above the temperature controls know, right? Thanks. Will give this a shot when I get home.
    Thanks for the tip about a replacement. Will talk to my plumber and make sure he's replacing mine with one of these units (you're saying that A.O. Smith and all these other ones are comparable since they're owned by A.O. Smith, right?).
    Nov 2008
    Quote Originally Posted by hadoob024 View Post
    Very Good "Grasshopper"
    May 2011
    atlanta
    Sweeeet! I'm learning. Last night I was calling the various parts "thingamajig" and "that-thingie" and "that hole".
    By the way, what are your thoughts on GE water heaters? A friend mentioned it.
    Nov 2008
    That's bottom line Whirlpool. Stik with my recommendations. Not that I have a clue
    Nov 2008
    FYI
    Grandfather - Master Electrician, Gas Technician. Started company 1899
    Father - Master Electrician, Master Heating Technician
    Uncle - Master Plumber, Master Heating Technician
    Myself - Just a beginner with 46 years HVAC/R, Building Maintenance, New York City Refrigeration System Operating Engineers License 1968, Suffolk County Limited Electricians License, Limited Plumbers License.
    Former Technician - RCA service, Amana Refrigeration, General Electric Appliances, Carrier Building Services.
    But what do I know. LOL
  1. Kenmore (Whirlpool) 665 leaking badly from door bottom
    By tahani in forum Whirlpool/Roper/Estate
    Last Post: November 8th, 2012, 02:09 PM
  2. Kenmore model 25358087898 water cup leaking
    By Steve53 in forum Sears Kenmore
    Last Post: October 25th, 2010, 06:54 AM
  3. Replies: 12
    Last Post: May 1st, 2010, 05:18 AM
  4. Bosch DW and tankless water heater
    By JDR in forum Bosch
    Last Post: September 7th, 2007, 05:21 PM
  5. Kenmore Refrig leaking water on floor
    By mneren in forum Sears Kenmore
    Last Post: July 17th, 2007, 09:38 AM
