Results 1 to 10 of 11
Thread: ice maker not working/water dispenser is
    Jul 2011
    Kings Mountain, NC
    Unhappy ice maker not working/water dispenser is
    Model Number: KSRG25FKST16
    Brand: KitchenAid
    Ice Maker will not work but water dispenser is working in the door. Filter was replaced about 45 days ago so it is fine. Anybody help?
    Jul 2006
    TEST FOR WHIRLPOOL OPTICS
    Open the freezer door and check the status LED
    2 Blinks followed by a 1 second delay-repeated: Tape the emitter door back so it doesn’t block the beam
    2 Blinks followed by a 1 second delay: Bad optics Part# 4389102
    LED is on steady: Optics good
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jul 2011
    Kings Mountain, NC
    Did the testing of the optics as you suggested, LED light stays lit. I noticed that the tray behind the teeth that sends the ice through was frozen solid so I used a hair dryer to thaw this out. Got all of the ice out of there but it still is not working. Any other suggestions? Thanks so much for your reply!
    Jul 2006
    Ohm the coils on the water valve. Should be 2-4 ohms.
    To force cycle the ice-maker, remove the cover over the module and locate holes “T” and “H”. Take a small piece of wire bent in the shape of a U and short “T” and “H” together. The ice-maker will start the harvest cycle. Wait about 10 seconds and remove wire. The Ice maker will continue through the cycle. At the end of the harvest cycle the ice-maker supplies the coil on the water valve with 110 VAC.
    Yes, I agree with rick, also you can direct test your ice maker water valve solenoid with a cheater test cord, read here about that:
    http://www.applianceblog.com/mainfor...-solenoid.html
    Jul 2011
    Kings Mountain, NC
    Replaced icemaker with new one.......done the "cheater" test, module is woking at base of refrigerator, icemaker filled with water but NO ICE.....?????
    Jul 2006
    Quote Originally Posted by sfjumper View Post
    Explain exactly what you did with details. You said the optics are good, the water valve is good and you have a new icemaker. Put water in the icemaker and see if it dumps a load of ice.
    Jul 2006
    Is the freezer cold enough to make ice??
    Jul 2011
    Kings Mountain, NC
    Yes
    Jul 2011
    Kings Mountain, NC
    When we completed the cheater test the icemaker filled with water....
  1. New ice maker - still no ice
    By dkpeppard in forum Sears Kenmore
    Last Post: June 28th, 2011, 08:01 PM
  2. Replies: 10
    Last Post: July 16th, 2009, 08:17 PM
  3. Superba Ice Maker and Water Dispener
    By Jake in forum KitchenAid
    Last Post: February 3rd, 2009, 10:52 AM
  4. Complete Ice Maker Assembly - For In-Door Ice Models
    By Jake in forum Refrigerators & Freezers
    Last Post: April 29th, 2008, 12:56 AM
  5. Ice Maker Not Working: KitcheAid Superba
    By Hookem in forum KitchenAid
    Last Post: February 2nd, 2008, 05:05 PM
