Results 1 to 4 of 4
Thread: Frigidaire #FGFL67DCA burner has weak flame
    Jul 2011
    SoCal
    Default Frigidaire #FGFL67DCA burner has weak flame
    Model Number: FGFL67DCA
    Brand: Frigidaire
    I have a Frigidaire stove model # FGFL67DCA that is about 6 years old. During the last few months, the flame on the front right burner (which we use for most cooking as it's the largest) has been getting weaker and smaller. It's now very weak and has a hard time lighting.
    The burner base is clean, as is the gas orifice. I am assuming that the valve has gone bad and delivers too little gas even when fully open to provide the proper flame size. Does this sound correct?
    I was going to buy a new valve and wanted to know if there are any particular tips or tricks I should know about. I assume I'll need to use either pipe dope or the yellow teflon tape to properly seal the connections.
    PeterM
    Yes, thats correct. So if the burner assembly and orifice is clean and clear then its the right-front burner valve thats going bad.
    I use pipe dope thread compound on the new burner valve threads, the stick type, you can get that at any hardware store.
    Remember unplug your range and turn the gas off to your range first.
    Here's the right-front burner valve for your model you can order here:
    Manufacturer's Number: 5303935236
    Jul 2011
    SoCal
    Thanks for the help. I'll get the new valve and replace the old one. I was planning on unplugging the electricity and turning off the gas, but it never hurts to remind.
    PeterM
    Yup, thats true Peter.
    Keep us posted.
  1. LG Gas Range; uneven super burner flame
    By Dvinechild in forum Ranges/Ovens
    Last Post: June 16th, 2011, 06:57 AM
  2. Frigidaire range front burner wont stay on
    By doanh in forum Frigidaire/Tappan/Electrolux
    Last Post: April 5th, 2011, 11:07 AM
  3. Jenn-Air Burner Cartridge High Flame Only??
    By bb137 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: June 16th, 2009, 12:09 PM
  4. Frigidaire ES400 burner won't spark
    By novasports in forum Frigidaire/Tappan/Electrolux
    Last Post: November 26th, 2007, 07:56 PM
  5. Frigidaire FEFL88ASC Burner Out
    By Jimmy Olsen in forum Frigidaire/Tappan/Electrolux
    Last Post: September 18th, 2007, 01:14 AM
