Results 1 to 5 of 5
Thread: Jenn-Air Range/Oven - Error Code F1-8
    Aug 2010
    Waterbury, CT
    Default Jenn-Air Range/Oven - Error Code F1-8
    Model Number: JDS9860AAB
    Brand: Jenn-Air
    Hi Jake -
    You've been dead on in the past so here we go. I have a Jenn-Air Range that is displaying error code F8-1. According to previous threads, it would indicate that the touch pad is defective.
    MODEL #: JDS9860AAB
    S/N: 17292706AT
    I'm just looking for your opinion to confirm as the part is (as you probably know) $ 267.00. Thanks a million Jake.
    Aug 2010
    Waterbury, CT
    I just returned from the house and now the error code in the display reads: F1-7. Any thoughts?
    Jul 2006
    F1-7 is basically the same thing as F1-8.
    F1-8 Shorted key (pad) in membrane switch.
    Ensure ribbon cable is securely connected, inspect
    ribbon cable and connector (shorts, breakage,
    corrosion, etc.). If OK, replace control.
    OWNER RICK'S APPLIANCE REPAIR
    REFRIGERATION SPECIALIST
    Jul 2006
    Make sure you have the ribbon connector all the way in. If so order the control panel:
    Touchpad 74005750 Order now for same day shipping. 365 day return policy. RepairClinic.com
    Dec 2013
    wis
    if youre getting this error code and youre left with this fairly lame diagnostic which is basically, replace one expensive part and if that doesnt fix it,, replace the other expensive part,,, try this.
    get under the edge of the touch pad (there are two layers here stuck together) and slowly peel it away from the backing. youll know that youre doing it right if you see a set of black rectangular lines on the face plate that correspond to another set of black rectangular lines on the backing. these are the contacts and one of them has probably shorted out. i got this error after cleaning my range and i think it got wet in between the layers. as youre peeling the layers apart you should notice a 3rd layer that helps separate to front and back. this layer is clear and it really doesnt matter which side it remains stuck to but it seems to want to stay on the back layer. now you may have to leave this to dry for several hours and you can gently rub the contacts with a dry cloth if you notice that any grease has penetrated the layer. after youre pretty sure its clean and dry, hold the face plate over the backing and try entering numbers or functions. if it works, then you have just successfully diagnosed and repaired your range. it is fair to note that the face plate will probably not stick very well when you reapply it, but if you dont have $250 laying around or you just need it to work until your new part arrives, you can just tape it back in place (i would use clear shipping tape).
    there is no high voltage in these layers so you need not worry about turning the oven off while youre working on it, but there are some blogs that suggest turning the power off to your range for up to 2 hours might help it reset.
    good luck
  1. FIXED: Freezer cold, but Warm fridge side - not cooling? Air flow 101 - HELPFUL INFO!
    By PatrickM in forum Refrigerators & Freezers
    Last Post: November 29th, 2014, 12:30 PM
  2. Cotrol board replacement for Jenn Air Refrigerator Model/Serial JFC2087HRS/10208490EX
    By mhsu_2000 in forum Maytag/Magic Chef/Admiral/Jenn-Air
    Last Post: April 25th, 2011, 11:46 AM
  3. Air Conditioning Repair FAQ:
    By Icehouse in forum HVAC
    Last Post: March 2nd, 2009, 10:20 AM
  4. Replacing old Jenn Air cooktop and ovens
    By dibiaggio in forum Maytag/Jenn-Air Reviews
    Last Post: August 21st, 2007, 06:19 PM
  5. Jenn Air Downdraft Cooktop Replacement
    By mfrank2109 in forum Antique and Retro Appliance Chat
    Last Post: October 5th, 2006, 11:39 PM
